Question about Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
My Norcold Fridge gives a fault code of ''A'' when I try to run it on AC.
It will run on Gas.
I had this happen long time ago but do not remember what I did to fix it?
Thanks,
-Larry
  • lecarlisle Apr 03, 2009
    This is a model N621 that is installed in a travel trailer.
    New Friend:
It's definitely an AC fault. Check the input voltage after you've made sure your glass fuse is ok. If it is, check AC heater. Here is an article on how: Norcold Fault Codes AC HE or On light flashing 3 times What to do
Posted on Sep 12, 2016
  • 332 Answers
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
  • 1 more comment
  • king ranch Sep 13, 2010
    I have the same issue with my refidge. changed the board and still wont work. I checked the breaker it also runs the microwave it woks fine. any thoughts?
  • tredding Aug 06, 2011
    The AC Heater element may be bad and will need to be replaced. Check the fault code for the refrigerator. Mine is an N61X and it is intermittent three flashing on the front panel of the refrigerator.
  • Margie Henderson
    Margie Henderson Sep 12, 2016
    3 flashes is an ac heater fault. It's different. Either a bad heater or a bad board. Here is an article:http://thenorcoldguy.com/norcold-technic...
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
My Norcold model 663. Is not switching to AC.
When gas is leaking, first fridge will stop working, than the freezer. I hope you dont have gas leaking. Is the compressor running all the time?
Dec 03, 2017 | Refrigerators
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Aug 16, 2012 | Refrigerators
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Sep 02, 2009 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
1,678 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
