Question about Exercise & Fitness
How to lube belt for Tempo 632T treadmill - Exercise & Fitness
    New Friend:
Do not use wd-40 on your bearings. That will only clean it and dilute the bearing grease that came with it from the manufacturer, thus hindering it's longevity. Axle/bearing grease is the only solution here. And as mentioned, 100% silicone lube between the belt and deck. Ensure to properly tension the belt so it does not let the roller slip, while in use, and possibly burn the belt.
Enjoy!
Posted on Jun 25, 2016
SOURCE:
  • 15 Answers
SOURCE: no. where on the treadmill do we lube the belt?
NO, But you may lube the rollers, that ajust the belt tension
Posted on Oct 25, 2010
ercupa190
  • 12223 Answers
SOURCE: What kind of lube should be used for the bearings and walking belt of a proform 625 treadmill?
1) for deck belt use 100% silicone LUBE
2) for bearing use WD-40 Or similar.
God bless you
Posted on Nov 30, 2012
  • 14 Answers
SOURCE: treadmill says to lube belt,
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
SOURCE: horizon treadmill won't start running
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill Horizon 7900 says Lube Belt
Dear Sir:
I will help you, please do the next step with video, with patience and carefully:
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=KiEZDNe0F8Q&feature=related
WITH THIS YOU WILL FIX IT.
If you need further assistance, please reach me.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 15, 2011
Error message E1 on tempo 632t treadmill - what is it and how can I fix it ?
Hi There,
Tempo....check this lower control board for a small potentiometer or little square cube with a screwdriver slot in the top. Adjust this pot CW to 3/4 full turn and retry. Check feedback sensor(s). Does the belt move and then error and stop, or never start? These lower boards do fail and you can contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 11, 2017 | Exercise & Fitness
My treadmill has gotten stuck in the highest incline position??
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 21, 2016 | Tempo Fitness Model No. 632T
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Need owners manual for a tempo 632T treadmill
Says to lube belt did that but still saying lube belt. Won't run when the safety key is put in
Feb 20, 2012 | Life Fitness Exercise & Fitness
Treadmill owners manual for a tempo 632T treadmill
how do i lube my treadmill. it is now asking me to do this and stops, continually.
Feb 11, 2012 | Exercise & Fitness
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
2,173 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
