Question about Whirlpool AWZ410 Front Load Washer/Dryer
How on earth do u find auto dry?
We bought the machine so we can set it to wash and dry in one go... Supposedly you can do it but we don't know how. When u turn on the machine its ready to wash but if you hit dry it switches to drying mode rather than adding it to the wash cycle. The manual is useless. Any ideas?
  • 1 more comment
  • Anonymous Nov 15, 2008
    I want the dryer to work independantly from the washer but that seems impossible
  • Anonymous Feb 07, 2009
    HOW DO YA WORK THE DRYER , ITS DRIVING ME MAD
  • john-sands Feb 17, 2009
    not drying
  • 20 Answers
I don't know if this helps, but the washing machines I have used will only go straight from wash to dry if the wash is set to 'half load'.
Posted on Mar 13, 2009
  • 291 Answers
What kind of washer and what model#
Posted on Sep 02, 2007
SOURCE:
WHAT DOES CODE AD MEAN ON THE DRYER
If your dryer is set to "auto dry" the display will show AD initially and then may show a number which is the estimated time for the clothes to dry in auto dry mode. The display may also show CD (Cool Down) and DN (Done) during the cycle.
Feb 27, 2015 | Washing Machines
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
How to use a washer dryer belling 1200rpm can u set the dryer to come on when washer in use
hello
you really need the model number then you can go to the belling site and download the manal
Sep 20, 2014 | Washing Machines
Why is not running ?
Do not turn anything on if your home is not earthed . Turn off main isolater and contact an electrician asap.
Aug 07, 2014 | Hoover Washing Machines
I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | LG Washing Machines
When i switch washing machine on it fuses all electic items in house
What you probably mean is that it kick out the earth leakage in the house. You could either have a neutral wire that has shorted to earth or water has gotten onto your circuitry and is enough to kick out the earth leakage - which it is supposed to do. Try drying out the electrics of the machine with a fan heater or a hair dryer for a while and see if that solves the problem. If not do a check from the neutral wire to earth with an ohm meter and see if you get a reading. If you do, you will have to trace all the wiring looking for the leak. If the drying out solved the problem, you need to look for a water leak.
Mar 27, 2011 | Indesit Washing Machines
Quiy zapp
This is what the actual Quinny Zapp manual says. If you machine wash it and it shrinks, they will not cover a replacement under warranty, so beware.
Care and Maintenance
Spot clean pad with cold water and mild soap. Air dry.
Periodically check for loose screws, worn parts, torn material or loose stitching. Tighten or replace parts as needed.
Whenever you wash things like this in the washing machine, it is best to do a delicate cycle on cold and hang dry to avoid any shrinkage or damage to the material.
Good Luck! from Moms Just Know
Oct 14, 2008 | Quinny ZAPP Stroller
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Not sure whats wrong with my washing machine!
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Oct 16, 2007 | Zanussi FJS1225W Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
393 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
