Wharfedale 37 inch lcd tv
My tv has just started to have green stripe at top and bottom sometimes and pic is greeny will it cost alot to fix and do u know wots wrong with it cheers
  • Anonymous Nov 26, 2007
    Just recently a green distortion has started to show up on the screen. However, it only seems to appear on the digital channels. The HD channels seem to be ok. I have Charter cable and am not sure if the problem is coming from the TV or cable provider.
  • Anonymous Nov 29, 2007
    I have a scott lcd 32" tv and there seems to be vertical green lines on the right side of the screen. It has been getting worse with time. Does anyone know how this can be fixed.
Open up the back and clean the connector to the display gets dusty
Posted on Aug 15, 2008
I have a phillips 37 inch lcd hd tv and sometimes when i go to another channel the screen is green then i turn it off and turn it back on everything is ok,also when i go to a diifferent channel no sound, i turn it off and back on its ok.please help
Posted on Dec 31, 2007
Kweltech: how do you address screen control. there isn't a parameter on my
Posted on Oct 06, 2007
SOUNDS LIKE THE LCD DISPLAY IS FAULTY. THERE IS NOT A SCREEN VOLTAGE ON LCD TV`S !!!!!
Posted on Sep 14, 2007
    Problem Solver:
  • 6 Answers
Sounds like screen control is set too high
Posted on Sep 03, 2007
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
I own a magnovox 50 mf2311d-37 plasma tv >when we power the tv on the green light comes on trhen about 3-5 seconds later it goes out and a red light comes on Pleae tell me what the problem is why...
this is a common problem, but it may or may not be a cheap fix. The capacitors that energize the screen go out alot on lcd's,lpasma's, and dlp's. The screen needs a surged charge to energize the screen, and the capacitors due this. Unfortunately, alot of capacitors put into the flat screen type tv's have a low quality set of capacitors in them. They should last for 15-20 yeaer, but alot of tv's capacitors are going out within the first couple of years. If your tv is under warranty, then take it to BestBuy, or Fry's electronics, as they have certified technicians foe this specific repair., If not still under warranty, you can still take it to them, but it may be a costly repair, as a set of high quality capacitors can be quite expensive. Sometimes the repair is more expensive than the cost of a new tv of the same exact size! Just bear this in mind.
Dec 17, 2010 | Philips Televison & Video
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
Black shadow on screen vizio 37 in lcd hdtv
There is a part inside the TV that needs to be replaced. If the TV is under warranty—whether the original warranty from the manufacture or an extended warranty purchased with the TV—call the company providing the warranty coverage and they will arrange to have your TV repaired at little, or no cost to you.
Since some brands will pay for your repair even if you're out of warranty, especially if they've heard of your problem before and it's a known issue. You should always contact the manufacture first for your full range of options. If they're willing to fix the TV for free, or at a reduced cost to you, let them!
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the TV yourself. Purchase the service manual from the manufacture to get started. However, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you decide to pay for out of warranty repair by a professional repair shop, the total cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Jan 11, 2010 | Vizio VW37L 37 in. LCD HDTV
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
All colour change on bush 37" tv
A wire in the set got too hot and broke away, had to pay £140 to get it fixed, was told it's quite comman in alot of lcd tv's, as in all makes... I t should have been for a lcd bush 37 inch tv,,,not that it makes any difference it applies to all flat lcd screens, I just posted in the wrong part to begin with.. Sorry.
Mar 27, 2008 | Acer AL2416WD 24 in. LCD Television
Televison & Video Logo
831 people viewed this question
Top Televison & Video Experts
