Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
Fitting New SATA Harddrive
I purchased two new Hitachi Deskstar 320 gig drives with the intention of replacing the IDE Drives in my current machine & reinstalling my XP operating system. Disconnected both hard drives connected one Sata drive to the SER1 interface port set the bios to boot from CDROM inserted my operations system disk and switched on but was told my system had no hard drive present. Switched off restarted went into the bios and asked it to search for hard drive but it did not find one. Wondering if there was a need to format the new drive I reconnected the Primary drive with OS and connected the Sata drive to the SER2 interface started up machine entered bios which told me no secondary drive was connected What do I do next Please????? Walter
  • 1 more comment
  • walter3 Sep 03, 2007
    Thanks mistyman, I've now downloaded this file 4/5 times but it still fails to recognize the 320 gig
    hard drive, indeed it tells me there is no hard drive fitted, although when booting up if I press Ctrl+F I go into some Raid configuration, that does recognize, that there is a 350 gig Hitachi drive fitted.
    jtra's solution, after accepting the fact that I have misplaced (or lost)the floppy that came with the system is, I'm afraid way beyond my limited capabilities Walter3
  • walter3 Sep 04, 2007
    Thanks fnshman, My BIOS (Phoenix Award)does not appear to have this option in the 'Integrated Peripheral' section. Walter3
  • Anonymous May 19, 2009
    sata isnot see hard dish
    Problem Solver:
  • 17 Answers
Did you check to make sure the sata interface in the bios is on. Not the RAID, just the sata. In the bios settings you'll find it under "Intergrated Peripherals/IDE Device Configuration". Make sure you enable both SATA1/SATA2 and SATA3/SATA4 if your not sure what plug you have your drive plugged into. Good luck.
Posted on Sep 04, 2007
    Problem Solver:
  • 8 Answers
You will need to hit F6 at the beginning of the windows install process to load the SATA/RAID drivers from floppy disk (assuming your system has a floppy drive and you have the drivers on a floppy disk). The alternative is to slipstream an xp install disk with the needed drivers. The easiest way to do that is using the free utility called nLite (http://www.nliteos.com/).
Posted on Sep 03, 2007
  • Jeff Tracy
    Jeff Tracy Sep 04, 2007
    Walter, you can get the drivers from the manufacturer's web site and simply copy them to floppy disk to do the F6 install during windows install. The only drawback is that you do need a floppy drive in the system. The ONLY alternative is to slipstream an xp install disk. At times, I have opted to temporarily install a floppy drive in a system just for this purpose rather than do the slipstream which is, as you say, fairly technical.
    Novelist:
    Champion:
  • 231 Answers
Hi, google msi, click mainboard, click download, click manualy download, click AMD, click ARCHIVE, you will find your mobo here listed as "MS657" everything you need will be there. Goodluck mistyman
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
Can't detect my harddrive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 15, 2010 | Hitachi Deskstar® (H3080A72S) 80 GB SATA...
This is a jumperles HD How to switch ftrom SATA
Http://hgst.com and download the hitachi tools for this drive. It is set via software.
TechRx, Inc. - Green Bay
Apr 19, 2010 | Hitachi Deskstar® T7K500 320 GB Hard Drive
Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
Feb 26, 2010 | Microsoft Windows XP Professional With...
My hard disc purchase date is march, 2006, It is not working can I replace it
Most drives are under warranty for three years from purchase date.
You can check to see if it's under warranty from Hitachi HERE.
Nov 24, 2009 | Hitachi Deskstar® 7K80 80 GB SATA Hard...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
HITACHI DESKSTAR 7250 320 GB HARD DRIVE
File on disk maybe bad. Try this website: http://www.mes.cbs.dk/~sttt/readme.txt and http://www.geocities.com/SiliconValley/Network/2963/files.html
Jun 23, 2007 | Hitachi Deskstar T7K250 160 GB Hard Drive
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
436 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Davit Mamyan
Davit Mamyan
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
