Question about Toshiba Satellite P105-S6207 Laptop
Laptop i have colour lines on my monitor it works ok on the big pc do you think it is a loose connection somewhere
  • jellybabies Sep 02, 2007
    how can i check if the connection is lose please
  • 78 Answers
Hi, This will be a problem with your VGA cable that runs from the LCD monitor to the motherboard inside the laptop. Sometimes it can just be loose ans disconnecting and re-connecting can solve the problem. If not then the cable will need replacing.
Posted on Sep 02, 2007
  • Austin Walters
    Austin Walters Sep 02, 2007
    How come you rated my reply as thanks for trying? "That was the answer you was looking for!!"
    Anyway. You need to remove the keyboard and you will see the connector its in a silver material tape and the head is flat.
SOURCE:
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Jun 03, 2012 | IBM ThinkPad T40p 2373 Notebook
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
My dell laptop lcd splashes the OS and then goes dark. It works fine with an external monitor. I have a feeling that there is a loose connection since the top is almost falling off
Think you have answered your own problem here. If the external screen is ok, then the fault lies with the laptop screen.
Solutions..
1.) Remove keyboard top cover (download a "how to" guide if not familar with doing this)
2.) Remove screen bezel
3.) Check the inverter connections (inverter looks like a thin tube)
4.) Check cabling from motherboard to monitor /inverter for signs of fraying, tears, bare wires
5.) Check connections of the cable for damage.
If the above are ok, then you may have a damaged inverter. In any event, i'd look to repairing the damage to the loose lid, as its putting a strain on the wiring
Feb 09, 2010 | Dell Inspiron™ E1505 PC Notebook
My inspiron 1525 is running weird. When i start it up sometimes it loads fine, other times the screen will start flashing multiple colours, or have lines of colours. What could be the problem?
Looks to me like your LCD cable is loose. You simply need to reseat the LCD cable. If you needs steps to do so I can provide them just let me know.
Dec 01, 2009 | Dell Inspiron 1525 Notebook
Vertical colour lines on laptop screen, when laptop moved screen sometimes works ok is it a big problem/
HI:
If you can test your laptop, by connecting an external monitor to it, that will tell you if it is a screen problem, or a video problem. If you get a good picture on another display, you have a problem with your lcd or inverter.
Nov 20, 2009 | Computers & Internet
Power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Sep 11, 2009 | Toshiba Satellite M35X-S111 Notebook
ASUS Eee PC 90 XP. Wont boot only displays vetical lines.
Did you try a external monitor to see is it works mine is doing the same think so I hooked up a external monitor and the computer is booting correctly i had to hit fcn and f5 for monitor to display. I think it might be a loose connection in the laptop.
May 16, 2009 | ASUS Eee PC 900 Notebook
Works on external monitor, but not on internal
No it's not motherboard problem u have to change monitor!!!
Oct 26, 2007 | Compaq Presario 1692 Notebook
No Display
First make sure everything else is getting power and operating okay, and that it is only the LCD display that is non-functional.
If you get no video signal or power at all, even at boot time, you probably have a dislodged ribbon cabling or power connection. Usually when LCD monitors go bad they show colour banding or all white, etc., but usually continue getting power.
As a last resort, try disassembling the lower case (with the power disconnected and the battery out of course) to expose the LCD monitor mounts, and then following the wiring from the screen into the laptop and check for anything loose or disconnected. You could also have a loose ribbon cable going into the LCD array, which will require disassembling the LCD cowling and mounts.
If you are handy and comfortable with electrics and find nothing loose, put the battery in and test the power line going to the LCD backlight, which should be getting above 7V (I think). Below that and you either have a bad video controller or bad wiring/solder joints somewhere. Otherwise, if the unit has been dropped or had a hard life generally, it could also be the connections between the LCD connector bus on the monitor array and the array itself. As a last resort, try unplugging and reconnecting all ribbon and connector cables, cleaning the exposed brass coloured runners lightly with rubbing acohol or even a pencil eraser.
Good luck...
Oct 16, 2007 | HP Pavilion dv2120us Notebook
Monitor problem
Hello. If the problem occurs only at some times (even permanent), this may indicate a faulty connector between the lcd display and the motherboard. It should not be an expensive repair unless there is something rong with the video chipset itself, but this in pretty unlikely. Try to move the display, bend it a little, watch out to see if any thing happens to the pink line, even a small change in colour, size or whatever. Or if you are willing to do this, I could assist you to dissasemble the laptop and check the connections yourself, but I don't recomand unless you have some experience and the basic tools.
Jan 24, 2007 | Acer Aspire 3003WLCi Notebook
Open Questions:
See all Toshiba Satellite P105-S6207 Laptop Questions
Toshiba Satellite P105-S6207 Laptop Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
