5303P LCD 2Way Security System with Remote Start and 4Button Remot Logo
Anonymous Posted on Aug 05, 2013
Truck won't start yet again - locked up/disabled
Every now and then when my gf uses my truck it will lock up and won't start after sounding an alarm. We think maybe the wrong series of buttons gets pushed or something. Regardless, even after pushing the reset button it won't turn over. The only thing that has fixed that in the past is to unhook the battery cable for 30 minutes and try again. This morning even that didn't help. Any ideas??
David Hoover
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Aug 06, 2013
David Hoover
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
11432
Points
62
Check for other ground wires. That's the cause of most problems. Clean Battery post (+ and -) and trace them as far back as you can making sure they are tight and clean. Check fuses, make sure wires are tight on the starter. If that does not work take and unplug every wire on alarm itself. If she moves the seat up check near the brake pedal and look for bad connetions.
patricia ann
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 07, 2013
patricia ann
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
345
Points
6
Help me with this alarm solution i cant start my car cause of this remote
5 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jul 22, 2011
SOURCE: Hope you can help. Older
Sounds like you are in "valet mode". If you can find your model number located on the unit I could be of more help. But, you can try putting the key in the ignition, turn it to the on position, press the valet button located under the dash, in the glove box, or where ever it is located, and then turn the ignition off and you should be out of valet mode.
logosc75
Larry Spears
  • 625 Answers
  • Posted on Nov 29, 2010
SOURCE: Sometimes when I press the
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Anonymous
  • 6 Answers
  • Posted on Jul 16, 2010
SOURCE: HOW TO DISABLE PYTHON ALARM SYSTEM WITHOUT DISABLE
When the remote start is disabled with the Toggle switch there is no reason why the door locks should not work. Sounds like faulty installation.,
Alan H
  • 139 Answers
  • Posted on Nov 03, 2010
SOURCE: We just bought a used
The owner's manual for the Python 460HP can be downloaded via the following link:
http://www.directeddealers.com/manuals/og/python/G426P_07-05.pdf
Anonymous
  • 18 Answers
  • Posted on Nov 17, 2010
SOURCE: how do you turn da
It should be the same as the Avital 2 way LCD remote. Try pressing the "P" button on the back along with the unlock button simultaneously until the remote vibrates. If you got it right the remote will vibrate and you'll see a small symbol above the car on the remote that looks like a box with a vertical zig-zap line on each side. To switch it back to audible beep mode repeat the step and it should toggle the option back.
How do I disable the alarm to start my vehicle I can't find the kill button.
https://www.google.com/search?q=old+viper+alarm+disable+alarm
Viper Support Center - I need to temporarily override my alarm ...
Viper - Car Alarms https://www.viper.com > support > guideTitle=I-need-t...
This method has you open the driver door, then press the lock button, immediately followed by the unlock button, immediately followed by the lock button again.
Missing: old ‎' Must include: old
How to Disable a Viper Car Alarm - It Still Runs
It Still Runs https://itstillruns.com > disable-viper-car-alarm-7494080
Press and hold the "Arm" button on your remote until the alarm turns off wirelessly. Step 2. Open your car door, and use the "remote valet" method to stop the ...
Alarm wont stop going off. Car wont start. Any way to disable it?
Plug your ears first, open the car with key, open the bonnet to get to the battery, disconnect one battery terminal and cover this with rag to avoid a short circuit. That should reset everything - alarm, radio. Do not lock the car. After an hour reconnect the battery. Hopefully alarm will have reset and then use the key in the ignition. Hopefully starts but you should buy a replacement button for your car and security system. If alarm sound again, disconnect battery again and call an auto electrician.
My car alarm on a 2000 Mitsubishi mirage sounded all of a sudden when i tried to start it. How can i disable the alarm system so i can drive
Close all the doors and windows. Lock and un lock with the remote or at the driver door with the key. This should reset the alarm.
How to disable alarm on 1993ford exsplorer
Have you tried locking and unlocking the driver door with the key ?
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
I recharged the battery recently because the car didnt start. Got the battery on again and now the car makes a beeping sound every time. I try to start the car but nothing happens. Help please!
use remote to disable the alarm or close drivers door turn key in door lock lock and unlock car 3-5 times if you do not have an alarm remote to said car this will disable the alarm system
6helpful
2answers
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
1helpful
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed
I have the 5000rs-2W installed on my Audi A6 02. It starts fine but if the system is Armed (locked) the Alarm goes off when using the remote start.. If I use the remote start with the system...
I Sounds like the factory alarm has not been disabled or bypassed properly yet. The car thinks that someone somehow got into the car while it was locked and tried to start it. Had the same issue on my car and had to unlock then lock it again to start it.
Top Python Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
