Microsoft Windows XP Home Edition Logo
Monare Sam Posted on Aug 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant rip music in nero windows xp - Microsoft Windows XP Home Edition
Michael Green
Level 3:
  • Master 3,799 Answers
  • Posted on Aug 05, 2013
Michael Green
Master
Level 3:
Answers
3799
Questions
0
Helped
600183
Points
10177
Why would you want to? just use Windows media player to rip. It is part of the program.
1helpful
I can not copy an audio CD into my computer!
You can't copy Audio CD's to a hard drive. The .cda format is meant for only CD's. You have to rip them to some other format for a hard drive to recognize (such as .wma or .mp3).
How to rip an Audio CD using Windows Media Player
QUICK RIP
You can do a quick rip if the "AutoPlay" menu comes out when you insert a disk in your computer's DVD/CD drive.
One of the options under AutoPlay is to "Rip Music From CD (using Windows Media Player)" which will automatically launch Windows Media Player and the Rip menu. Make sure you uncheck the "Always do this for Audio CDs" box so your computer doesn't automatically launch the Rip menu every time you insert a CD (i.e. in case you just want to listen to a CD next time).
Start the ripping process by clicking on the "Start Rip" button (e.g. in Windows Media Player 11, for example, it's on the lower right once you're in the Rip menu). You'll also have an option to use your Internet connection and have Windows Media Player automatically find details about the CD you're using so you don't have to fill out album and song details yourself (for this tutorial, let's assume that you're not connected to the Internet, which means you'll end up with an unknown album with unknown songs). You'll know the ripping process is done once all the songs show "Ripped to library" under "Rip status."
By default, Windows Media Player will rip your tunes in WMA format and save it in your "Music" folder. You can access the folder by clicking on the Windows logo at the bottom left of your computer's screen. For Windows XP, for example, it'll be the "Start" button. For Windows Vista or Windows 7, it's the circular icon with the Windows four-panel graphic that looks like a waving flag.
Clicking the "Start" button in Windows XP will bring up a menu box with "My Music" as one of the options. For Vista, clicking on the Windows button will bring up a menu with "Music" as one of your options. Anyway, clicking on either of those choices will open your music folder. Look under Unknown Artist and you should be able to find the Unknown Album you just ripped. Once you find the songs, you can rename them one by one.
To do a normal rip, let's go to the next step.
NORMAL RIP
For more options, like changing your ripped music's format to MP3 or changing the folder where you save your music, you can do a normal rip.
Start by launching Windows Media Player yourself via the "Programs" option by clicking on either the "Start Menu" tab in Windows XP or the Windows logo in Vista or Windows 7 (both at the lower left of your screen). Insert your music CD. (To simplify things, just cancel and close down the "Autoplay" menu in case it shows up.)
Once you're in the Rip menu, click on the Rip tab to bring up a list of options. "Format" lets you pick between Windows Media Audio formats, WAV, and the more popular MP3 format. The WMA and WAV both have "lossless" format options, which means the music will be ripped with no loss in quality. The MP3 format, meanwhile, offers wider compatibility with portable music players and smaller file sizes but sacrifices a certain amount of quality depending on the bit rate of your file. This brings us to the "Bit Rate" button, which basically lets you pick the quality of the rip. The default for bit rate is 128 Kbps. Note that the higher the bit rate you pick, the better the quality you'll get, but you'll also get a larger file size.
========this worked for me and should work for you too, please let me know if it helps========
I cant download my cd's to my new hard drive?why
Copying files from a CD or DVD is a more detailed operation than down loading. In some cases you may need specialized software to accomplish the feat, such as Nero, In some cases you copy an image in order re-burn to another CD, in other cases you RIP music. See: http://portables.about.com/od/newsandviews/ss/how-to-rip-with-WMP.htm
on how to RIP music using a program in windows.
2answers
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Installed Nero, that came with new re-writer after installation of program Nero states incompatability with the version of Windows XP, and suggests contact of Nero, when clicking link to their page your...
I have heard of Nero not being compatible with Vista, but not XP. Are you positive you are running XP and not Vista? If you are sure you are on XP, make sure it is up to date by running your windows update. I cant' understand why our page would come up when you click on the Nero link tho.
Can Nero convert MP3 files to wave for ripping onto music CD's
Yes. Select audio CD as your disc type. Drag and drop your MP3 files into the Nero window.
You don't have to convert from MP3 to WAV. Nero will burn the CD in one hit.
1helpful
Nero express updates
here are updates for nero 6.
http://www.nero.com/ena/downloads-nero6-update.php
unfortunately, you cant cant use nero 6 on vista. you need to upgrade... nero 7 or nero 8.
http://cquirke.spaces.live.com/blog/cns!C7DAB1E724AB8C23!167.entry
hope this helps
Cds
Music CDs that are stamped by the factory have a format that Windows does not normally recognize, except thru Media player, or other aware programs. That music format is CDA. You need a CD ripper program to convert the CDA file to something Windows does recognize, like MP3 or WAV, then copy the files to your USB drive. Programs that rip CD music to files are UltraISO, Media Player 10, Nero, etc.. Here's one link to using Media Player to rip your CDs. http://portables.about.com/od/mp3players/ht/howtoripCDWMP10.htm This should get you started. ZT3000 Beta tester of "0"s and "1's"
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
