If fluid looks like water and open hose, Sounds like the drain for the air conditioner for condensation from running the air.
The waterpump hose and if theres a noise on the right hand side what problem is that
SOURCE: Purple fluid leaking from 2002 Volkswagen Jetta
the sound is your belts for the I recommend to pressure wash the area what till it drys then turn the engine on then look for the leak it would be easier to pin point a leak with a clean engine
SOURCE: I think the water pump is leaking. the car gage
Try to borrow a good size make-up mirror from a female friend. With the mirror in hand and as good small flashlight, look under the area of the waterpump while the engine is cold. You should see a greenish or redish stain on the bottom of the waterpump shaft. The pump usually only leaks when it's running and when it gets to cold temps. Place a piece of cardboard under the crossmember when you park the vehicle for the night and look the next day for leakage indications. Thanks, Dana
SOURCE: Small steady water leak from
Might possibly be a leaking heater core or a freeze plug on the side of the engine. A small leak might be patched up with some radiator sealer but I would show the leak to the mechanic who repaired the cylinder head first. Hopefully he missed something minor and solve your problem with ease.
SOURCE: clear fluid leaking from the front right side of a 2000 vw beetl
what type of power steering fluid for a 2000 vw beetle
SOURCE: clear fluid puddle
POSSIBLE A/C DRAIN, DO YOU NOTICE AFTER YOU DRIVE WITH A/C ON... DOES FLUID HAVE A SMELL OR OILY FEEL?
Here is a picture.
