Question about Maytag MER5750 Electric Kitchen Range
Burners not working on a Maytag Electric Range
We purchased a Maytag Electric Range in 2004, it is a Performa PER5750QAW. That is the code on my reciept. The back right burner has not worked for awhile and now the left rear one may be going out. How can we change the elements or whatever is in them and how do we even get the top open. Thanks sparklwoman
  • Karen Beikirch Sep 03, 2007
    Thank you so much we will try this and let you know how it goes! It is very kind of you to take time to answer this post!
  • Anonymous Mar 24, 2014
    replaced the 8" element, that wasn't the problem. Why else isn't it working?
  • 5,911 Answers
The top of the range will open if you remove the three screws under the front edge of the top. You will need to open the oven door to see them. But first, unplug the range or turn of the circuit breaker. There's still live voltages (240VAC) even with the range turned off. Also use care not to lean on the oven door or you could damage the springs. If the top does not have any brackets to hold it up you may need to find something to prop it up, or use a second set of hands. The elements are easily removed by removing a couple of screws and the some wires. Write down the wire colors and where they go to assist in making sure you reconnect them correctly. Also, pay particular attention to the numbered holes on the back of the element. Make sure you reconnect the retaining brackets in the same numbered holes as you removed them. Last of all, do not handle the ceramic material or element coil with your bare hands. They are fragile and the oils from your hands could create hot spots and potentially ruin the element. I do not know the arrangement of your elements, but I suspect you have one of each size burned out. The part numbers are as follows: 6" element: 1032743 9" element: 1035285 The prices are about the same ($40 ea.) with the larger element costing slightly more. I hope this helps you.
Posted on Sep 03, 2007
SOURCE:
Maytag performa range oven top
If there are any screws around or in the burners, they have to be removed first. Once all the screws are removed, use a blade to loosed the burner. Then try turning again.
if you do get it open, lift just an inch or two to make sure you are not stretching any gas lines. They will break then you will need a new stove.
Oct 20, 2013 | Maytag PGR4410 Performa Gas Kitchen Range
NEED A WHOLE DOOR FOR MY MAYTAG ELECTRIC RANGE MODEL #MER5750AAW
The door is not available as a entire assambly it is comprised of like 30 individual peices that make up the door, i included this parts breakdown for all the parts on the door.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MER5750AAW/3048/0124111/X2906094/00005?blt=06&prst=0&shdMod=MER5750AAW
Gene
Aug 03, 2011 | Maytag PER5510 Performa Electric Kitchen...
Maytag performa code: 5Ab
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
Press and HOLD the clock pad for 3 seconds to disable the sabbath mode. The range will return to normal functions.
Keep us updated and remember to rate and comment this answer.
Jul 05, 2011 | Maytag Performa PAV2200
Gas smell is strong on Maytag Performa when using the oven.........some times?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 23, 2011 | Maytag PER5710 Performa Electric Kitchen...
Lost our power now on our range we have clock working timer working and burners working. Try to put oven on & the lock button lights up. Try to put broiler on & lock button lights up. Nothing goes...
Ive had the same problem after losing power. I heard to unplug and plug back in the oven and it should work- didnt work for me. Then Ive heard to replace the control board. I found it for $141 on appliancepartspros.com I havent purchased it yet, still searching to see if this is really the problem
Feb 20, 2011 | Maytag PER5710 Performa Electric Kitchen...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag MER5750 Electric Kitchen Range Logo
308 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
