No water will enter the dishwasher the stop tap is switched on and the feed pipie is not kinked
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Inlet el-valve voltage measurement is 0 at any working mode.
What kind of sensors or switches to check next, and where are those?
I have a Zanussi DS 22 Aquasave. It was intermittently taking in water so I replaced the combined overflow and inlet valve. It worked on first use but no longer takes water in. Hose filters are clear and power is getting to the solenoid but still no joy! I disconnected the pressure sensor hose and sucked and blew and I could hear the pressure valve opening but still no water.
no water entering to wash dishes,
