Question about Aiwa AV-D58 Receiver
Hooking Components I need help hooking an Aiwa Receiver To a Sony VCR, And a Sharp TV and a GI Cable Box. Thank You
  • donald33 Jul 22, 2008
    surround sound not coming thru the speakers.
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=244 There are good diagrams to help you. When you have followed this guide then come back with any items you can get working. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 02, 2007
SOURCE:
The tv says no signal new out of box
It's kind of hard to answer your question with not knowing how your hooking up your TV. If you are hooking up a antenna or cable to your RF in you need to make sure you have your input set to TV and autoprogram your channels. If your using a cable box hooked to your RF in then you need make sure it is on and autoprogram your channels. If you are using a cable box, satellite receiver, or DVD player hooked up to your component, composite, or HDMI.input then you need to make sure you have you input set for that. Hope that helps.
Nov 29, 2010 | Sony KDL46EX400 46 in. HD-Ready TV
Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Jan 02, 2009 | Onkyo TX-DS575 Receiver
Hooking up my VCR
OK If you are running cable you would plug cable box into VCR then VCR out to the TV input red/white/yellow/ or a coaxl cable (like the one the cable companys Good luck and Thank you for using FixYa.
Dec 17, 2008 | Emerson EWV401 S-VHS VCR
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Hooking a dvd and vcr to a cable box and tv
You will have to use an audio/video cable for connecting the player to the tv. This cable consists of three wires, generally a white, a red and yellow. Yellow is for video and the other two are for audio. You will find corresponding colored sockets both behind the tv and the player, find out which is the input at the tv and output at the player. Good luck
Jan 30, 2008 | Sharp 25H-M60 TV
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
HELP! hooking up my components to eachother
Youll need to But a Rf Modulator that Converts Composite Video to Rf Using Channels 3-4 VHF Radio Shack Stocks it Any other Questions let me Know
Jul 19, 2007 | Pioneer VSX-406 Receiver
Aiwa AV-D58 Receiver Logo
130 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
