Question about Olympus MJU 400 Digital Camera
Olympus mji 700
When i turn my camera on in the view pictures mode with the memory card in, it comes up with two options:format and power off.if i try to format it comes up with card error message.in shoot mode the camera lens comes out, becomes blurry and a few seconds later returns back into the camera.when i switch it off the same thing happens and the lens pops in and out.also comes up with following error code: D:5f 08 34 02 5e 02 please help
  • 2 more comments
  • Anonymous Dec 27, 2007
    mju 700 problem started after I formatted the camera with olympus xD picture card pl. help same error D: 5f08 5e02
  • asos Feb 09, 2008
    I have this same 5f08 340a 5f 08 5e 02 error code. I have bougt this camera two years ago so i can`t but it back to a seller! What should i do? Can this be fixed?
  • Anonymous Apr 11, 2008
    when i turn my camera on in the view pictures mode with the memory card in, it comes up with two options:format and power off.if i try to format it comes up with card error message.in shoot mode the camera lens comes out, becomes blurry and a few seconds later returns back into the camera.when i switch it off the same thing happens and the lens pops in and out.also comes up with following error code: D:5f 08 34 02 5e 02
    please help
  • Roham Krishna Apr 27, 2008
    Mine is a Mju 700...and I have the same error - 5f 08; 5e 02...please tell me it can be fixed for a low price
    Genius:
  • 2,985 Answers
It has to go back the Olympus for replacement or to seller if less than one year.
Posted on Sep 02, 2007
3 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: 5f 08, 5e 02, Olympus 710, Help!
hi alexandra olympus cameras are know for having a few lens problems when ever a blue screen comes on the camera is faulty it sounds to me like you have some dirt or dust in the lens i have seen this problem a few times hope u get it sorted goodluck
Posted on Sep 28, 2008
SOURCE: olympus mji 700
sameeee problemmmm!
Posted on Oct 19, 2008
How do l free up my memory stick after downloading the pictures?
assuming that you are talking about a memory card ..just get into view mode..and on the menu choose storage ..than options and clear memory card ..or ..just again in view mode..choose a picture and options and when you try to delete will ask for multiple delete ...select them all and delete ..or just insert the card into a card reader and when it shows in the my computer folder open it ..select all pictures and than press delete ..
the fastest way though is to simple select in the main menu the storage ...in there select card ..and on options format card ...this will erase all on it ..and format it in the same time for best performance in the device ..
Jun 16, 2010 | Olympus FE-310 Digital Camera
Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 02, 2009 | Olympus Stylus 790SW Digital Camera
Cant get anything when i installed the memory card for my olympus
If this is a C-700 camera the only memory card that can be used in that camera is a Smartmedia card from 16mb to 128mb. An xD card is not even supported by that camera at all.
Apr 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
Memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Mar 22, 2009 | Olympus Cameras
I somehow managed to write protect so I cannot take pictures or transfer pictures to my laptop. How can I undo this? I have an Olympus sp 700 Thanks Durriya
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jan 10, 2009 | Olympus SP-700 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
I cant see my pictures
Can you check the card by a car reader in the computer- or some one else computer? Failing that Format the card in the camera then have a try Come back let me know how you get on
Jul 21, 2007 | Olympus FE-230 Digital Camera
Olympus MJU 400 Digital Camera Logo
218 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
