Question about Microsoft Office Standard for PC
Not equal to
When using if function and filters how do I pick out items that are not equal to the criteria I am using
  • 883 Answers
Using MS EXCEL: start the operand with the following: IF _<>_value is true, value is false example: Not equal to A1<>B1, IF A1 not equal to B1
Posted on Sep 02, 2007
Rheem Criteria II furnace filter location
If it's an updraft, filter may be at bottom of unit. Filters are usually installed in the return air side of the system. If you have a return air plenum it may be under a removable plate cover. Also check you return air grill inside your house, filter may be inside this grill,which have opening latches.
Mar 19, 2016 | Filter Heating & Cooling
Hi, how do I find the 1st 2 letters in a cell and reference it to another. ie A1: 0209JJP001. I thus want to find "02" which is Feb (this would be a vlookup I assume). Therefore the 1st 2 letters...
To reference the first letters in a cell, use the left function. The syntax is =left(cell,#). So, to return the left two letters from cell A1, you use =left(a1,2). You can put that in a cell or incorporate it into some functions.
Jun 12, 2009 | Microsoft Excel for PC
Reminder in excel
There are a couple of types of spreadsheet - Depending on the size of the data you are working with - filter may the quickest option or Query report.
Your worksheet will contain all your data i.e. Customer, contact no, outstaning actions and due date - You can create a filter aon this set criteria on the due data - as less than or equal to todays date - which will only display your outstanding actions required by today or earlier.
Another option if you have installed MS Query, is to create a seperate report - again using the criteria of due date being less than or equal to today.
Producing this from your existing data is much easier than trying to re-create your data - But I can send you how I would create this sheet if the above explanation is not easy to follow - If you let me have your email address.
May 31, 2009 | Microsoft Office Excel 2003 for PC
CountIF ORSUMIF
COUNTIF counts items that meet criteria. The SUMIF will "add" the amounts. I believe you want to use the COUNTIF() function.
Apr 28, 2009 | Microsoft Computers & Internet
Excel farmulas
Add another colum, say D with result of B*C
Do a list of the different cat, and use sumif
For cat 0101 (in cell F1)
formula to put in G1
=sumif($A$1:$A$7000;F1;$D$1:$D$7000) where F1 contain 0101
expand the formula for other cat. (G2, G3, etc)
You can use a assistant to extract the distinct cat from A1:A7000, sorting them and copy the result in F (Menu Data-> Filter -> elaborate filter)
Feb 16, 2009 | Microsoft Excel for PC
Suction paower
First thing is to check all your hoses, and filters. Filters rob your vacuum of air flow which equals power.. I don't think that you have a clog so much as I am inclined to think that you have dirty filters. In a wet vac, you can rinse your filters out, but they will eventually need replaced. It's a good idea to have an extra filter around for such an instance.
Jan 19, 2009 | Rainbow E series Canister Wet/Dry Vacuum
If function in exel
For Current Date - you can use the =Now() function in your cell where you want the date.
For Contract #, I don't know what you're using, but you can link to a database of contract #s (see below), or you can name a range like current contract #, which gets updated by 1 each time you add another contract, which then is automatically posted on your EXCEL
DGET(database,field,criteria)
Database is the range of cells that makes up the list or database. A database is a list of related data in which rows of related information are records, and columns of data are fields. The first row of the list contains labels for each column.
Field indicates which column is used in the function. Enter the column label enclosed between double quotation marks, such as "Age" or "Yield," or a number (without quotation marks) that represents the position of the column within the list: 1 for the first column, 2 for the second column, and so on.
Criteria is the range of cells that contains the conditions that you specify. You can use any range for the criteria argument, as long as it includes at least one column label and at least one cell below the column label in which you specify a condition for the column.
Jul 15, 2008 | Microsoft Excel for PC
Sumproduct or conditional sumif with multiple criteria in vba code...
i'll just reply to your conditional sumif query.
yes, you can do multiple criteria query but with a matrix formula. you may look it up. nonetheless, here is how one would look like:
{=sum(if(range1=A x range2=B x range3=C, sum range))} note that x (multiplication) is used to denote intersection of the criteria
initially, you'll enter it as:
then, edit the cell (F2) and press ctrl+shift+enter for the brackets { } to appear.
Jun 27, 2008 | Microsoft Excel for PC
Excel Formula
Lets say your data (cars) is in range "D1:D21".
You need to know how many are Dodge and Ford in cell E1.
=COUNTIF(D1:D21,"Dodge") + COUNTIF(D1:D21,"Ford)
Hope this helps.
Apr 22, 2008 | Microsoft Excel for PC
Excel formula question
mmm...could be tricky......you could try the argument IF THEN ELSE in the functions list, in conjunction with additional columns to carry out the intermediate calculations, then you can hide those columns. perhaps you could also make use of conditional formatting. any problems come back to me.....could you place a snapshot of the sheet you are designing ? just highlight the cells , copy them, and use edit "paste special", tick values when pasting into this forum.
Jan 18, 2008 | Computers & Internet
Microsoft Office Standard for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
