Question about Betty Crocker BCF1690 Bread Maker
Betty Crocker bcf1690 motor problem
When we turn the machine on motor does not rotate. I can select all the programs though. It is 5 years old. How does the machine open up if I want to repair it myself. Technical support is difficult to get as I am not living in U.S.
  • Anonymous Apr 07, 2008
    belt is worn and keeps slipping off so motor does not rotate
    New Friend:
Sounds to me that you may need a new drive belt. Not easy to find out of the country, but Moulinex (sp) products may work. Your drive belt needs to have treads on the inside of the belt. To gain access to the area where the belt goes, you must take out the baking section, including the actual pan. Remove screws on the bottom of the unit as well.
Posted on Feb 03, 2010
I have used my machine once. When I tried to use it again a horrible clanking and metal sounding noise came from the machine. It only happens when the bread is kneading. I tried running the machine without bread dough to see if it clanked and it didn't. Franklin, the makers of the machine are of NO help. Apparently they fired all knowledgeable people when they stopped making the machine! Can anyone out there give me a clue as to what to do to fix it??
Posted on Jun 17, 2008
Have the same machine, had the same problem. you need to open the bottom of the machine where you will find a large gear (search for screws - the display thing pops off too so you can reach in and unscrew) . the spindle in its middle should not be turning freely. If it does, use whatever means possible (crazy glue, epoxy, maybe heat, etc) to attach the spindle to the disk. did that, and it worked fine for another 2 years. -turgut
Posted on Oct 08, 2007
SOURCE:
I don't have manual for Betty Crocker Bread Machine
Just though I would let you guys know if you are looking for a Betty Crocker Bread Maker model bc-1691 Recipes & Manual you can call 1-800-446-1898 and General Mills, owner of Betty Crocker, will send you a manual free if you give them a call.
This Betty Crocker bread maker was made by ACA and is no longer in production but they have a few maunals left they will mail out.
Nov 24, 2011 | Betty Crocker BCF1690 Bread Maker
Where can I get a new bread pan for my Betty Crocker Bread Machine Model BCF1690
Try this link. BCF1690 is same as Betty Crocker ( at least the last time I checked).
http://www.amazon.com/Oster-Sunbeam-102529-000-000-Bread-Pan/dp/B000PJBFDW/ref=cm_cr_pr_pb_i
It will cost you about $30.00 with shipping.
You can get a new one here for only $56.00 warranted for 1 year.
http://www.amazon.com/Sunbeam-5891-2-Pound-Programmable-Breadmaker/dp/B00067REBU
Hank
Jul 14, 2010 | Betty Crocker BCF1690 Bread Maker
Looking for a bread machine manual the bake it easy 2
You can find a manual to your bread machine by clicking on this link:
http://www.bread-maker.net/Bread-maker-reviews/Bread-Machine-Reviews/Betty-Crocker-BCF1690.htm
It is downloadable in pdf format and listed at the bottom of the product features.
Feb 20, 2010 | Betty Crocker BCF1690 Bread Maker
Need instruction manual for a betty crocker bread machine model 1692
http://www.scribd.com/doc/17867738/Betty-Crocker-Bread-Machine-Model-BCF1690-Instruction-Manual-Recipes-BCF1690 - Check this link and see if this helps!
Oct 09, 2009 | Betty Crocker BCF1690 Bread Maker
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Sep 22, 2008 | Betty Crocker BCF1690 Bread Maker
Hello, While not cheap you can find parts for your bread machine on ebay. Click here for a link This link is for paddles but the seller whose store is "Breadmaker parts outlet" says he has others. Good Luck! Dr. Know
Dec 27, 2007 | Betty Crocker BCF1690 Bread Maker
Hello, While not cheap you can find this item on ebay. Click here for a link. Good Luck! Dr. Know
Nov 20, 2007 | Betty Crocker BCF1690 Bread Maker
Bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Mar 06, 2007 | Betty Crocker BCF1690 Bread Maker
Betty Crocker BCF1690 Bread Maker Logo
289 people viewed this question
Top Betty Crocker Kitchen Appliances - Others Experts
Harjeet Singh
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Betty Crocker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
