Question about LG GCE 8481B CD-RW Burner
Missing DVD driver
I have a new packard Bell with windows Vista Premium. My optiarc optiarc DVD RW AD 5170A ATA device has dissapeared. I have done searches, uninstalled the driver and rebooted amongst other things but still no luck. I get the following when trying to select from device manager - Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
  • Blochie Sep 02, 2007
    I am still very lost around computers so please excuse my ignorance but I dont even no what a bios is. I did howevever try updating and i get a message saying that my pc allready has the best driver software available for my system. I am so lost and confused.
  • miepmobiel Mar 28, 2009
    i get error code 39, same story: new packard bell, optiarc did work until few months ago, is not recognising anything (cd's, empty cd's, dvd'd whatsoever, cannot find driver on computer (and driver detective doesnt help either...HELP!!!)
    Champion:
  • 207 Answers
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
Posted on May 18, 2008
I wish I can use the system restore but not going to as it has gone for while and other things will not work if I go back.
This happened to me today and I used system restore and that brought my drive back.
Posted on Sep 04, 2007
See if it is recognized in the bios if not , the bios does not recognize the hardeware and you will have to update. dvd- cd-rom drives generally do not need drivers , only software to use them.
Posted on Sep 02, 2007
6ya staff
SOURCE:
Optiarc dvd rw ad-7585h ata device driver for window 7
szukam sterownika do Optiarc dvd rw ad-7585h ATA
Nov 01, 2010 | Computers & Internet
Windows vista updated and now my optiarc dvd rw drive won't work
You will have to uninstall the drive and reinstall again. I think the drivers for the drive is not properly installed. But if all this does not work, then I think you will have to do a system restore.
Best wishes
Oct 29, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Optiarc DVD RW AD -5170A ATA Device keeps telling me to insert a disc. Help
Make sure the cd your inserting is not scrachted or has fingerprints on it. If it's a clean cd then your cd rom is most likely broken.
Oct 10, 2009 | Gateway (5500652) (  5500652)...
Driver
Is this a windows XP or Vista unit? You are getting that because either the driver is still not installed or you have installed an incompatible driver for your CDROM.
Aug 08, 2009 | Sony Optiarc AD-7170S Burner
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
Dvd device!!
do that device is a new one or not? its a malfunction,, maybe. if do have the warranty deal with it as early as possible.
Jul 13, 2008 | Computers & Internet
Optiarc DVD RW AD-5170A ATA Device
Old, failing writer or poor quality discs perhaps?
Jan 28, 2018 | LG GCE 8481B CD-RW Burner
LG GCE 8481B CD-RW Burner Logo
805 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
