Question about Xincom XC-DPG602 Router (XCDPG602)
Asus Router Can you please help me how to install a Router in my PC? I would like to use my Internet while using my telephone at the same time. Thank You
  • 1,139 Answers
Re: Asus Router
Ok I am goin to make some assumptions here, you have dial up service right? first you need to get DSL which allows you to use your Internet and phone at the same time on the same line. The other choice is to get cable modem service which frees up your telephone line because your internet service will be coming over your cable connection. Once you have DSL or cable modem you will need to connect and configure your router. plug the ethernet cable from your Cable modem or DSL Modem into your Router's WAN port the plug your PC into the Router's LAN port. Your PC should pull an IP address using the DHCP protocol. You can check this by opening up a cmd prompt window in Windows and typing in the command ipconfig and pressing the enter key. Once you have your ipaddress (which should be xxx = some number between 2 and 254) try to ping the gateway address by typing in ping and hitting the enter key. you should get 4 ping return indications. Once this happens log into your router via the default gateway IP address ( from your web browser by using the default login and password (these default settings should be in your documentation but the log in is admin or leave the box blank, and the password is admin) once you are logged in set your WANconnectivity for DHCP (cable modem) or PPPOE (DSL). then for DSL put in your login and password given to your by your DSL provided, for cable modem just select the save button (for both) and the the router should pull a WAN side IP address. check this by looking at your router's WAN settings. once you have don this you should be able to connect to the Internet.
Posted on Sep 04, 2007
0 characters
3 Points
HP Officejet Pro L7650
The problem could be your web browser and its settings. You can try using another computer, or another browser. If you are using Internet Explorer, dry downloadingFirefox and accessing the router again. Hope this helps.Can you tell me which Internet Service Provider having you use. If your physical connectivity is pour or every minute or while reconnect your physical connectivity then your router also reconnect your ISP so router ask you password conformation for that.
If you using DSL connection then you do first that check your telephone wire physical connectivity and also if you have multimeter than check telephone wire voltage if is not stable than your telephone connectivitiy is pour so called telephone mechenic for that.
if everything is ok than ask your router company.
Dec 05, 2011 | Linksys Wireless-G Broadband Router
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Please help me connect my sony ericsson x10i using my usb cable to my pc so I can connect to internet on my pc as my mobile as an outside telephone line.Thank you.
assuming u have all ur box contents for ur phone..
i suggest u load the dvd/cd provifded by sont x10i box
install their pc suite and in tools click connect to internet...
the solution mentioned assumes u have the cd or know how to get it off from internet and the internet settings on ur phoine are correct .
May 10, 2011 | Routers
Hi, I have got RTG32 router installed for a small business (5-6 ) machines .From machines I can see and update router settings but I can't see internet line working from router. Internet is working...
Do you use a username and password provided by your ISP on the computer to connect to the internet? If yes, these need to be entered into the connection settings of the router. Are you connecting the internet line to the WAN port on the router? Did you install to your computer the ASUS utilities? Try the EZ Setup utility. You can download the manual from this link
Mar 09, 2011 | ASUS RTG32 Router
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows...
May be your modem is not configured correctly by bsnl.
call up your telephone exchange ask for the correct details of the connection and try again.
If it still doesnt work ask for a replacement of the modem.
Feb 09, 2011 | ASUS Routers
When i connect with the internet and my phone rings, the internet connection is interrupted and I cannot use the phone and internet at the same time. please helps
I'm goign to asume here that you have DSL by your problem. If I am incorrect then please let me know.
With that said, first you need to check that your dsl filters are correctly connected and functioning correctly. If you hear a static or fuzzy sound on the telephone even echo this will be the casue from a bad filter or non-existing filter.
A filter that is bad or missing will cause DSL to drop its connection. The telephone call will cause too much interruption with the dsl signal and causes the modem to drop the connection to reconnect with a more solid connection.
So what you need to do is check your filter by changing it as well as checking this problem that it happens on all phones not just one individual.
Please get back to me if you need more information or this does not help you.
Jan 27, 2011 | 2wire (2701HG-B) Wireless Router
Can 3 computers (1 desktop and 2 laptops) share the same IP address?
No. Each device connected to a network must have a unique address so that data can be properly routed. If you want to share an Internet connection among several computers, you need a router. The router provides a single IP address connection to your service provider on one side. Then each computer connected to the router, wired or wireless, gets its own internal IP address from the router. As data comes over the Internet, the router takes care of getting it to the proper computer.
Dec 06, 2010 | D-Link DIR-615 Wireless Router
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
Aug 14, 2010 | ASUS RTG32 Router
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
Nov 06, 2007 | ASUS WL-500g Wireless Router (WL500GDLX)
Open Questions:
See all Xincom XC-DPG602 Router (XCDPG602) Questions
Xincom XC-DPG602 Router (XCDPG602) Logo
147 people viewed this question
Top Xincom Routers Experts
 C. Dante
C. Dante
Are you a Xincom Router Expert? Answer questions, earn points and help others
