Question about Electrolux EOG7330WN Gas Double Oven
Tripped out when the oven gets hot, the fans come on but it has tripped out on a number of occasions. I've had an engineer out, who pressed a reset button behind oneof the knobs, but I can't seem to find anything, does anyone have any clues to the location or what the reset button looks like, or why an oven 18 months old should trip out regularly? Thanks
  • bobobunny Dec 19, 2008
    I have the same problem did anyone find the reset switch?
Take off the oven knob, behind is a piece of plastic - the reset switch is behind that.
you have to poke a smal screwdriver in and should hear a small click
Posted on Jan 06, 2009
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
How to fit an element in a cda dc730ss oven
You have a wire loose or breaker tripped. Turn off breaker to oven then reset it.
Feb 24, 2013 | Ovens
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
All funtions on oven r working ie lights fan and grill but wen on oven setting it will not get hot please help
Have you had any problems with your electricity "tripping" when the oven is in use? If so I would suggest that the oven element needs replacing or on rare occasions the emergency thermostat is faulty.
The oven element is generally found under a metal plate in the bottom of the oven( inside) and its terminals are found by taking the back off the oven.
The emergency thermostat is located in the rear of the oven and looks like an over sized watch battery on an oval mounting plate.
Neither of the parts is overly expensive and far cheaper than a new oven.
Hope this helps.
Mar 04, 2011 | Zanussi Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Electrolux EOG7330WN Gas Double Oven Logo
708 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
