Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Numark cdx plays originals but skips on some copys have tryd half the speed to give better copy but not working
  • 4 Answers
Have had a few issues with cds not reading very well, on intial spinup and random looping and skipping during playback. The CDX's weak link is the cheap CD drive used, and I found replacing the laser solved it for me.
The laser itself is a Sony unit, KSS-213C. I found one on Ebay for around £10 all inc, from a company called LittleDiode (http://stores.ebay.co.uk/LittleDiode). If you're handy with a screwdriver and a soldering iron, it's not too difficult to replace. During fitting, don't forget to desolder the link on the edge of the board that protects the unit during transit, or it won't work when you power up!
At £10, it's a lot cheaper than having Numark sell you a whole new CD drive for £100+!
Posted on Mar 27, 2008
Hi, i would try using different cdr recordable media or try a different burner if this dosent help then i would say your laser is at fault or in some cases i have had the servo pcb going faulty on this model. hope this helps. regards. paul.
Posted on Sep 04, 2007
How too conect numark cdx turntable to numark dm 1002mkII
All you have to do is to connect the 2 RCA audio line out from the CDX at any pair of the 4 line inputs (RCA too) at the 1200mk2. Keep in mind: Don't connect the CDX out at the PHONO inputs of the mixer.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | Numark CDX Turntable
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Best Media to use for DVD playback
The laser eyes on mobil units are relatively cheap and low quality. If you keep playing copied discs(any format), it will make them "tired"(out ot alignment) from trying to focus on low quality encoded discs and render it useless. Original discs are produced with equipments and programs that cost ten of thousands of dollars that why they tend to retain the encoded info longer even when exposed to direct sun light for times and easier for unit to read. But if you are like the rest of us going to junk that player after a couple of years in service then use Verbatim Platinum dvds, they are quite high in prices but retain info much better than others. But remember they are still copied discs not the original articles and might one day cause your players to fail completly. Goodluck.
May 01, 2008 | Jensen VM9510 Car DVD Player
Numark cdx
I'm sorry to tell you this, but my advice would be to buy a pair of Pioneer CDJ-800s or CDJ-1000s
I can't see the 800s costing you much more that what paid for the Numarks, and there's a reason why the Pioneers are used extensively in nightclubs, and the Numarks aren't.
Mar 20, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdx
i have all the same problems as the person above. and it makes me want to throw them in the garbage.
Mar 18, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
My Numark CDX Cd drive wont open, but it will still play..
If you haven't sent it in the You see the four screws Were You put the Cd in at? Take them Out... then There is two tab on the bottom where you pull the drive out but be careful when taking apart
Nov 04, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
473 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
