Home | Thermador | SC302T Electric Double Oven | Error F5 comes on whe...
Thermador SC302T Electric Double Oven
Problem for Thermador SC302T Electric Double Oven
Error F5 comes on when trying to bake
By vonemsters on Apr 03, 2009
The upper oven stops with an error F5 when we are tryig to bake. We have a Thermador Model SC302TS.
Comments:
Apr 03, 2009
- Thanks for responding to my problem. I have a Themador model SC302TS double oven. When we press BAKE - 350 degres - Bake, the oven tries to start heating then stops with an error code F5 displayed.
I don't have a user manual to determine what F5 means. My s/n is 81100080 if that helps.
Apr 03, 2009
- Thank you for trying. I turned off the power for more than 3 minutes before reapplying power. The same F5 problem still occurs. I'll call a service man.
Thanks for the manual. That will help considerably to know how to approach problems in the future.
Thanks for your assistance.
Clarification Request
Posted by localwonder on Apr 03, 2009
Are you sure that's an F5? i don't see a F5 in my code manual...
Best Solution
posted on Apr 03, 2009
Helpful)
localwonder
Rank: Guru  Ovens & Ranges  Expert
Rating: 92%, 2676 votes
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Comments:
Apr 03, 2009
- No problem, glad to help:)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Thermador SC302T Electric
Questions and Unsolved Problems for Thermador SC302T Electric
Do you recommend Thermador SC302T Electric Double Oven?
Answer
Answer
thermador oven element - seems soldered in place, not screwed..
Answer
Thermador SC301 single electric oven: the oven sounds like it is coming on (e.g., when you hit... (More)
Answer
Our Thermador sc301t takes a long time to heat up and even when it says it has reached temperature,... (More)
Answer
I have a Thermadore double oven, convection on top and regular oven below. Model SC302TS. None of... (More)
Answer
oven keeps saying f24 we reset several times. oven now keeps shuting off itself. what should we do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Thermador SC302T Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
