Question about Philips MWD2206 DVD Player/VCR
Setting up the chanel on the VCR
I misplaced my owners manual/flyer that showed how to set the dvd/vcr to the correct channel. I know you have to press a certain button and wait for the light. I forgot. Can you help me?
    Problem Solver:
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Posted on Sep 04, 2008
SOURCE:
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
I unplugged my Sanyo DVW 7000 DVD/VCR 4 head Hi-Fi system for about a half hour, while we were moving furniture. When I plugged it back in I couldn't get it to work. I can turn it on manually and get the...
I am not sure if you unplugged all the cables from your VCR to your TV, If so double check the hook up. When you unplugged the POWER to the VCR the memory was lost. Try and find the menu or set up on the remote. Again the audio out from the VCR needs to be hooked to the audio in on the TV and the video out from the VCR needs to be hooked up to the video in on the TV. Keep trying !!!
Jul 28, 2010 | Sanyo DVW-7000 DVD Player/VCR
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
I only have cable tv. when i connect my magna avox
This unit does not have a tuner to receive TV broadcasting. If you have the owners manual on page 26 it explains this. If you do not have the manual here is a link to one.
http://www.magnavox.com/pdf/mn/DV220MW9_mn.pdf
Sep 05, 2009 | Philips Televison & Video
I put the wall cable to the vcr and the cable to the tv to the vcr, and i put the vcr on channel 3 and want to record channel 31, it records channel 3
you state here you put the vcr on chanel 3 but you want to record 31. put the vcr on chanel 31 to record
Aug 01, 2008 | Televison & Video
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Help
you'll need to bring up the menu, under "channels" or "set-up" you will find something called autotune (or manual channel set-up). it will automatically set the channels you pick up.
May 28, 2008 | Philips Magnavox 20MC4304 20 in....
Can't setup Magnavox DVD VCR recorder
Put your TV onto chanel 3 to pick up your Magnvox signal
Jan 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips MWD2206 DVD Player/VCR Logo
161 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
