Question about Gainward GeForce PCX5750, (128 MB) Graphic Card
Problem with pcx5750
I ve just purcheased geoforce pcx 5750 I have asus motherboard,intel celeron cpu,2.8 MH,512mb ram,160gb HD. my problemis that my computer is totaly blocked afterfew minutes from use and somtimes it cant work at all untill I reboot and sometimes everything is fine this is happened after I used the pcx5750.I checked the cnnections and fan they were ok ,any help?
    Novelist:
  • 231 Answers
Hi, sounds simple to me, Not enough RAM for what you are asking from your system. I would go to at least 1Gb RAM and if you can afford it 2Gb RAM, you can never have too much RAM but you most certainly can have too little. Regards mistyman
Posted on Sep 02, 2007
SOURCE:
EMachine W3507, will not boot after adding 2GB of memory. (2x 1GB; one in each slot). It will boot with one stick, but only if the original 512MG is in slot 1. The 512MB is not recognized.
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
Sep 06, 2013 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Asus k55vd wont power on. power button lights up when hit, but nothing happens, no sounds from HD or fans.
for display problems, check peripherals.. specially the ram's contact. rubbing contacts with eraser might help
Aug 23, 2013 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Compatible Processors
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
Installed Qty (Max Supported)
0.0 ( 1.0 )
Memory
Cache Memory Type
None
Supported RAM Technology
DDR SDRAM
Supported RAM Integrity Check
Non-ECC
RAM Installed ( Max )
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
5.1 channel surround
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion / Connectivity
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
I just changed my monitor and my new monitor is not coming on, it works with other pcs but when i insert it in my pc which has an Nvidia pcx 5750 graphic card de monitor gets a signal but the screen is...
Have you checked the bios to see if onboard graphics have been disabled.
You may also have your resolution/refresh rate set to high for the new monitor.
Boot into safe mode (F8 on boot)
This will boot with minimal drivers, your monitor should now come on, if it does then go to you display settings and lower the resolution and refresh rates.
If it does not come on in safe mode, try hook up the old monitor, or another monitor to reduce the resolution
Sep 21, 2010 | MSI PCX5750-TD128, PCX5750, 602-8969-010,...
I am looking for specs for a dell motherboard e139765
Dell Bluford e139765 motherboard:
Chipset: Intel 845GL with ICH4 southbridge Socket: 478 CPU Support: s478 Intel Celeron and Intel P4 400/533 FSB (BIOS rev A04 or newer required for latest models) RAM Support: 2x DDR PC2100 128MB-512MB (non-ECC) Sound Card: Analog Devices ADI 198x Integrated Audio Form factor: Non-ATX LAN: Broadcom BCM4401 10/100
USB: 4
Nov 18, 2009 | Dell Computers & Internet
My PC is not installing XP service pack 2
You'll need to upgrade your RAM, minimum requirements for windows xp is 512MB.
for the best price on ram go to http://www.pricewatch.com
i would recommend at least going to 1 or more gig.
Mark
Mar 27, 2009 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Core (TM) 2 duo processor E7300, socket LGA 775, freq. 2.66 GHz, FSB 1066 MHz, L2 Cache 3MB, PCG 06, core 45nm what asus motherboard should i buy
buy any motherboard BUT asus.
asus tech support is rubbish.
i run my system on an ASROCK motherboard.
excellent boards, 2500mhz bus, can handle any cpu, most have 4 ram slots.
Feb 24, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
I have an asus p48vx-x motherboard
you may check
1) your Intel pentium 4 3.2 GHZ cpu socket 478 processor #sl7nb what's FSB?( see on the chip surface, if 533 FSB can use but 800FSB could not match your motherboard if which is not support 800 FSB. that's why no display.
2) check RAM stick speed, try to increase a level, for example 266 to 333.
is this helpful please feedback thanks
Feb 12, 2009 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Upgrading CPU
This motherboard? asus p4s800d-x?
Nope - No
Intel Celeron or Intel Pentium 4 Cpu's for this motherboard.
Sep 14, 2008 | ASUS P4S800D-X Motherboard
Gainward GeForce PCX5750, (128 MB) Graphic Card Logo
69 people viewed this question
Top Gainward Computers & Internet Experts
Ekse
Alun Cox
Are you a Gainward Computer and Internet Expert? Answer questions, earn points and help others
