Question about Maytag Portable Air Conditioner M6P09S2B
Portable a/c water problems
I have a 9,000btu Maytag portable a/c and it was working fine but recently it started to beep for full water tank. I would drain it but a few hours later, same thing. I'm thinking there is a water evaporator problem? Any assistance you could give me would be greatly appreciated. Thank you!
    Problem Solver:
  • 7 Answers
Either the area you are cooling is extremely humid or your a/c is freezing up, shutting off  and melting alot of ice before it comes back on.
Posted on Oct 16, 2007
SOURCE:
Whers does water evacuate from portable ac unit
there is a holding tank in the bottom of the unit, on the front right by the floor is a rubber cap that plugs this tank. water evaporates from there, if the tank gets too full, the power button will flash red and the unit will not turn on. put pan under, pull plug and drain if this happens. if it doesnt happen, don't worry about exhausting the water as its not a problem.
Jun 10, 2014 | Maytag Portable Air Conditioner M6P09S2A
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have the portable danby premiere #317825 model#DPAC11010 its the 3-1 portable air conditioner we just got it last summer and today for the 2nd time in the last month it is shutting its self off there is...
The water is being removed from the air, you need to empty the water out of the unit as needed, sometimes as often as every two hours, the beeping is a water tank full alarm telling you to empty the tank as per instructions, there is a drain plug on the bottom of the unit you may want to move the unit to a drain until you know the amount of water the tank holds so you know how big of a containor to use
Jul 22, 2011 | Heating & Cooling
The water empty indicator keeps flashing indicating we need to empty it BUT it is empty !!!!Now the aircon won't work We emptied a lot of water however now it keeps beeping a warning,the compressor shuts...
I am NOT aquainted with the Maytag Portable AC..... But There has to been a sensor that tells the unit that the water bin is full...... If there is any moisture on the sensor and touching a ground probe then even though the bin is empty the sensor is still making a connection to ground. If you can trace out the wire that goes to the sensor you can unplug it from the board till it dries out or you replace it..... Only if you do make sure you empty the bin often or you will have water every where because the unit won't shut off if the water bin is full..... Hope this helps
Feb 05, 2011 | Maytag Portable Air Conditioner M6P09S2A
30 horse power '88 Mariner motor won't stay started
If you have portable tanks, some have screens under the coupler assembly. They could be dirty. If you have more than one tank, you could switch out on the water. Make sure the bubble pump is hard and full of gas. It is not uncommon for some outboards to need choking to start even when warm. This is an updraft carburetor characteristic.
Jun 24, 2009 | Light Outboard Motor Boat Bass Fishing...
Heating & Cooling Logo
374 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
