Question about Lexmark X73 All-In-One InkJet Printer
Printer problems Hello, my printer is not printing the things i want. I have paper in the paper feeder, but it still wont print, can you help me.
  • Anonymous Dec 27, 2007
    updated my browser from explorer 6 to explorer 7 and my printer now does not print off internet. however it will print a test page or stuff like notepad but will not print off internet after installing Explorer 7. What could be the problem?
  • Preciousbaby Jan 01, 2008
    My printer prints directly from the printer but not from the comp[uter. Dell support checked the problem and indicated everything was connected properly, and I should contact Dell. It shows the number of documents waiting to be printed. I have disconnected and reconnected cables, restarted both the computer and printer. Nothing is working. I tried the online HELP and even that didn't work.
Purchased new HP media center amd 64 with Vista and am unable to get my photosmart 8150 printer, or Lexmark 8350 all in one to print at all. help!
Posted on Dec 17, 2007
SOURCE:
SAYS IT IS OUT OF PAPER WHEN IT ISNT AND WONT PRINT
I have the same problem with a Kodak printer I have. I sometimes have to put more paper in or take some paper out to get it to print. It looked to me like the feeder roller was messed up.
I am going to get a new printer as soon as the ink in this one is used up.
Mar 06, 2015 | Office Equipment & Supplies
Lexmark printer wont print
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
My IP2700 got a paper jam.I successfully removed the paper manually and the printer looks normal. Turned off and on the printer and rebooted the laptop however, whenever i tried printing, it tells me it...
Please check your paper feeder from your printer, press the paper feeder tightly and turn on the printer... don release to hold the paper feeder until the process is complete.... thanks
Aug 14, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Print wont print
You have the paper inserted wrong in the printer. The paper should be inserted behind the feeder wheel that is on the right side of the feeder shoot
May 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
