Question about SanDisk Sansa m240 MP3 Player
Volume control stopped working
My Sansa m240 has been working great, but this week the volume control stopped functioning. I can turn 'down' the volume but it does not respond to turn back 'up'. So, the volume is all the way down now. Any ideas how to fix? I took the unit apart and pressed on the little buttons... same problem (volume down worked, volume up did not work). So, it seems like the actual switch is not functioning. Maybe I can "reset" it or something? Do they warranty this type of problem? It is about 9 months old now.
  • reikini Dec 01, 2007
    yes, same problem, volume control worked fine. then the next time I turned it on it doesn't work and there is no sound.
  • Anonymous Apr 18, 2008
    How did you take it apart?
Well at least mine isnt the only one
Posted on Jul 22, 2008
Also having the same problem... Must be faulty.
Posted on Dec 10, 2007
Take the warranty and the MP3 and go to the shop from where you bought. They will repair for you.
Posted on Sep 19, 2007
SOURCE:
Cannot download music onto sansa m240
Double check that you have space left. If you do, then reformat the player and start over.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 27, 2008 | SanDisk Sansa m240 MP3 Player
Please help me
-Tha Mp3 Doctor
Nov 24, 2008 | SanDisk Sansa m240 MP3 Player
Sasa m240
-Tha Mp3 Doctor
Sep 18, 2008 | SanDisk Sansa m240 MP3 Player
My sandisk sansa m240 not working with my windows xp pc
Uninstall all Sansa software and reinstall it from CD.
If that fails:
-Tha Mp3 Doctor
Aug 19, 2008 | SanDisk Sansa m240 MP3 Player
Dead
-Tha Mp3 Doctor
May 28, 2008 | SanDisk Sansa m240 MP3 Player
I NEED DESPERATE HELP
If Windows Media Player is not recognizing the player, try the volume +/Recovery method and then reformat the player inside Windows Media Player.
-Tha Mp3 Doctor
May 24, 2008 | SanDisk Sansa m240 MP3 Player
My PC and my MP3 Player aren't speaking to each other!
-Tha Mp3 Doctor
May 16, 2008 | SanDisk Sansa m240 MP3 Player
My sansa M240 WonT turn on all the way
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa c240 MP3 Player
Taking apart Sansa m240
take the screw out on the back then pop it off with fingernails
Apr 18, 2008 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
278 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
