Question about Samsung Digimax S800 Digital Camera
How do you turn the volume up on the video for samsung digimax s800?
SOURCE:
SOURCE: Samsung S800
I have the same problem Having forced the lens out, it retracts when I power off and back to square one. My solution is to force the lens out (was horrible grating sound) and then power off by opening the battery door. The lens stays out when you power on again and it still takes good pictures. Not ideal but better than a new camera.
Posted on Jul 13, 2008
tazdev
  • 75 Answers
SOURCE: my samsung digimax s800 stopped
Try to replace the battery with rechargeable ones.
And if that doesnt work, call 1-800-SAMSUNG and have your camera sent for service.
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Posted on Feb 24, 2009
  • 6 Answers
SOURCE: my samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
  • 4 Answers
SOURCE: Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Posted on Apr 23, 2010
Why does card error keep coming up on Samsung digimax s800
Make sure it has been inserted the correct way. If so, try another card. If After checking those things you still get that message, you may need a repair
Feb 19, 2015 | Samsung Digimax S800 Digital Camera
I can't install my card in samsung digimax S800
What type and size memory card? The S800 uses MMC and SD cards. It will not work with SDHC cards even though they'll fit into the slot.
Dec 22, 2012 | Samsung Digimax S800 Digital Camera
How to set the timer for samsung digimax s800
Press right on the multiselector (marked with a one-handed clock) to cycle through the self-timer modes. Start the self-timer by pressing the shutter release button.
Aug 02, 2012 | Samsung Digimax S800 Digital Camera
What is the max size sd card used for video in the SAMSUNG DIGIMAX s800
SD cards max out at 2GB. Higher capacity cards are actually SDHC cards (the HC stands for High Capacity).
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera. When the camera via usb is on, "my computer " freeze.
Having gotten no response in over four months, I assume my suggestion to use a card reader solved the problem.
Nov 15, 2010 | Samsung Digimax S800 Digital Camera
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
My digimax s800 takes 2 double a batteries can i run it with a dc
According to the Samsung website, the Digimax 800 uses a BP1310 7.4V Lithium-ion rechargable battery, not double "A"s. You can download the manual at the following link: http://www.samsungcamera.com/popup/download.asp?prol_uid=1170&prj_uid=348
Mar 02, 2010 | Samsung Digimax S800 Digital Camera
Lost manual for samsung digimax s 800,,,can cam be used as webcam
You can get the manual at the manufacturer's web site:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04010300&prd_mdl_cd=&prd_mdl_name=DIGIMAX+S800
No. The S800 cannot be used as a webcam.
Mar 15, 2009 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
74 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
