Dead t v
I have a sylvania ssl2006, and we got it around christmas. Recently it died for no apparent reason. What do you think happened and is there anything that can be done to fix it?
  • 1 more comment
  • papparazzi79 Nov 22, 2007
    i got on dec 05 and on on aug 07 i start geting dificulties turning it on for about 2 days and on the last day it did not turn on after more than 5 atempts (including unplug off and on) now when i plug it on it start making a fine buz loud sound and going low on volume at the same time the stand by light start dim and slowly get brighter like is not geting enough power. and some times the screen is on but with no signal and all the butons does not respond at all.
  • whstv Feb 11, 2008
    Yes, I have the same exact problem.  I got my first sylvania ssl2006 in Feb. of 2007.  We plugged it in and nothing happened... so we took it back and got a new one.  Now exactly a year later my tv will not stay on longer than thirty seconds, the light dims and then shuts off.  It's very frustrating.  I do not have the receipt to take this one back.  And now i am without a TV again!  I do not recommend a Sylvania to anyone because of the problems.  It's a shame because the performance was excellent.  If anyone has any idea how to get my TV to work please let me know!
  • Anonymous Mar 04, 2008
    Same TV, Sylvania 2006, same situation. TV purchased 5 months ago, worked fine. Now, you turn it on and it shuts off in 30 seconds the first time, when not warmed up. Turn it right back on and thereafter it turns off within 5 seconds.
Screen blinks, stops like a DVD on pause only we aren't watching a dvd. There is also a click sound when this happens and it also affects the audio. Screen does not go black or blank. Motor boating, discharges and starts again. This set is not two years old yet. Very annoying to watch.
Posted on Sep 07, 2008
Good Luck! My SSL2006 tv would cuts off when turned on. Under warranty, the local auth. repair shop tried unsuccessfully to replace parts to fix it. In addition, the repair shop told me it was difficult getting thru to parts support. Either the wrong parts were sent, the right part didn?t work, or additional authorization was required to repair TV. On many occasions I made calls to Sylvania, on the repair shops urging, to find out the status on its repair parts to help get the right parts sent. The set was in an auth repair shop from Feb.-Aug. The shop couldn't fix it. It was sent to Sylvania's repair center in CA, August 18th. WHEN WILL I GET MY TV BACK? I want a new TV!! I have been without this TV for over 6 mos.! I'm very upset with customer service and its repair centers and will never buy nor will I recommend purchasing a Sylvania product.
Posted on Oct 05, 2007
SOURCE:
Sylvania ssl2006 wont stay on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2015 | Sylvania Televison & Video
Sony Cyber-shot DSC-H7 Battery Life is Only Hours Now
Can you verify that your charger accessory is working correctly?
Jan 06, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Sylvania ssl2006
How do you know it is the fuse? Did you take it apart and look at the power board? If so, what is the model number?
Aug 12, 2013 | Televison & Video
Manual for sylvania tv model SSL2006
your best bet would be to contact Philips who makes this or Google the model number with "manual" to try to locate one.
Jun 17, 2012 | Televison & Video
Model SSL2006 will not accept TV (cable) channels above 13.
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Oct 06, 2010 | Sylvania Televison & Video
Sylvania SSL2006 dead, won't turn on. fuse is ok,
Hi larry
Since you know electronics that will make the explanation simpler;
On your tv model there is a very common problem that you may want to look at;
There is a small board on the right hand side(backlight inverter board),
Look for a shorted D309 , it is a 9.1volts 1watt zener diode.
As i said it is a common problem for your model.
But there is also the power supply;
All lcd tv`s nowadays it seems end up with bad capacitors in the power supply,
You can recognize them by their rounded tops and you`ll find them at the output of the power supply along the 5/12 and 24volts line.
But especially on the 5 volts line.
If your not sure which ones then replace them all (there might be 6 or 7 of them) it won`t hurt and eventually they will go anyway.
Hope this help good luck
Jan 08, 2010 | Sylvania Televison & Video
Turns over but wont start
Briannatara:
Some questions to help in the analysis........
You say "it cranked for about 3 seconds and died as if I turned off the key" did it actually start and then die?
Have there been any clues (unusual happenings) recently that might relate to the current problem?
Is there a reason the battery went dead? was something left on? Lights, etc?
How old is the battery?
Loringh
Nov 09, 2008 | 2002 Kia Sedona
Televison & Video Logo
370 people viewed this question
Top Televison & Video Experts
Ekse
