Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite canyon capacity washer
Just ran my day old kenmore canyon capacity top load washer. worked well on the first two loads but now it will not work on load number 3. i am getting the 'lid' message. i reviewed the trouble shooting in the manual and it simply askes is the lid open. i turned the power on selected the load added soap, fabric sofner, and color safe bleach. closed the lid pushed start and i get a full circle of lights around the load indicator a beeping and the 'lid' message. i turned off the power and unplugged and attempted again but no luck. any suggestions
  • Anonymous Mar 23, 2014
    When you load it and close the lid and push the start button sometimes the washer will not come on and I have to unplug it and mess with the button several times before it will come on
You are in bad shape. Your sensor that supposed to close your cover might be broken or malfunction. I just had my problem last week and i very pissed. This will cost you almost the same price as you buy a new machine. $59 for sears technician to diagnose your machine, $156 ht got labor charge and $230 dollar for that bad part. The same machine cost around $660 dollar at the sear store right now. I am trying to fix it myself if I can.
Posted on Sep 06, 2007
  • 291 Answers
Check out the lid switch ... move it up and down slowing and see if you can hear the lid switch clicking.. lid may not be hitting just right or something... should also be under warranty
Posted on Sep 02, 2007
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
What is the capacity of Kenmore model
This may or may not help.
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.$FILE/L-55.pdf
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore elite canyon capacity top load washer
check lid switch make sure its makeing contact right should hear it click
Sep 02, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis HE Canyon Capacity
Your door switch may be bad and not sensing that the door is shut which is what I see alot on those washers
Sep 01, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
209 people viewed this question
Sal De
 Brian Main
Brian Main
