Question about Gateway MX6448 Notebook
No Power Actually it's a Gateway MX6436. I have a power issue. 1. When the AC adapter is plugged in, I get no power 2. I remove the battery and let the AC remain, no power 3. I put the battery back in with the AC connected and I get a blue light 4. I press the power button and everything goes away, no power. Any suggestions.
  • 457 Answers
You know I had a problem like that at sometime back and I found that the CPU unit had come loose I dont how but it did so I pust it back in solid and away everything went. Cost nothing to try just you ego......goodluck
Posted on Sep 02, 2007
How to turn on a NV5378u gateway laptop
1. Charge the battery for 2 hours,
2. Press the power button.
If the laptop does not start, you can do this:
Please use the VGA port (VGA external monitor), also please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your GPU/motherboard is dying.
Mar 09, 2014 | Gateway NV5378u Notebook
Why won't my gateway MD78 power on?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
No a/c power light on laptop
Well the first thing you should check is the amount of power output to the power supply. for example the computer needs 12V but the AC Adapter only gives 9V.
If that's not it then the actual green light is not receiving that information from the motherboard. that's not an issue if the battery get's filled up and the laptop works normally . If you notice that the laptop tends to shut down quickly when it's not plugged in then the battery is worn out. These things happen since the a laptop battery becomes very inefficient after 2-3 years.
One more thing - try to rotate the input end of the ac adapter cable. maybe it's not making good contact inside the laptop.
Hope this helps.
Feb 02, 2012 | Gateway MT6705 Notebook
Gateway M-7315U, Ser# 83506341425, no power
I had the same problem. Could be that the motherboard is retaining a charge. #1. unplug ac/dc adapter and also remove battery.#2. Press the power button and hold it down for 15-50 seconds. This will drain the board of any residual charge that may interfere with it powering up.#3. Leave the battery out and plug in the ac/dc adapter (to eliminate the battery being the problem) now press the power button. It should start up.
Jan 28, 2012 | Gateway M-7315U Notebook
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
I need a power adapter
If you want real cheap, then an universal AC adapter is your best option. Targus has one that you can purchase for 24.99 USD, which you can find here.
That adapter works for a wide variety of manufacturer's including Gateway. Also, this particular adapter can provide up to 70 watts of power. So any adapter that fits into that range will be fine on power consumption.
Your AC adapter takes approximately 65 watts of power and should be okay.
I hope this help.
Apr 22, 2010 | Gateway MX6436 Notebook
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
No power on has had no issues but now will not power on
Remove the battery and AC adapter. PRESS the power button down and hold it down for 20 seconds. Put the battery back in and plug in the AC adapter. Try to power it on. This is called a power cycle reset.
Jul 30, 2009 | Gateway Computers & Internet
Gateway lap top is not getting any power, the power light is off any solutions?
1. First of all, go to and enter your serial number to make sure you still have warranty (just in case you need to order parts or send in your lappy) 2. You can open a chat window with gateway to describe to them your issue 3. Possibly order a new part, or fix the solution via gateway support.
ps. My suggestion is either a bad power cable, or bad battery. They will probably send you a new one of either for free if you still have time left on your warranty. Otherwise you'll have to pay, but it'll fix the issue. If you have any further questions, reply to
Apr 13, 2009 | Gateway Computers & Internet
Gateway MX6448 Notebook Logo
155 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
