Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite canyon capacity top load washer
I just ran my day old kemore elite washer. On the thrid load i am getting a lid message. i have reviewed the trouble shooting guide in the manual that simply suggests is the lid open. First it allows me to choose the load setting, i put the soap, fabric softner and color safe bleach. close the lid and press start and that is when i get the lid message. there is no water in the tub just small load of clothes. Any suggestions for my 800.00 fancy machine that is not working?
  • 291 Answers
Check lid switch make sure its makeing contact right should hear it click
Posted on Sep 02, 2007
How do we get rid of the UL code on our Kenmore Oasis Canyon Capacity Top Load Washer? It stops on the final rinse and spin cycle with nine minutes left.
Thwere is a switch under the lid that will not spin the tub, if the lid is up. This may be bent or broken. Lift lid and shine a flashlight down the slot underneath the protrusion on the lid. you should e a'plank' across the hole. No plank the swithch or the ;Plank" is broken. Most likely the plank, or actuator.needs replaced.
To replace , and or check the actuator, you have to remove the top of the machine. On a Kenmore here are 2 screws at the top back of the washer thaqt hold down 2 metal plates that go up to the back of the control panel. When the screws and plates are removed you can pry up the top of the washer with a stout screwdriver. after removing the top you can un screw the safety inlerlock, that's what I call it, and check for the bent/broken actuator or broken switch. If all looks okay then you need to take an ohm meter and check for continuity through the switch. Place one test lead at each end of the switch, removing and marking the wires on the switch. Press the actuator and you should see less than 5 ohms on the meter, if that is okay, then it gets more involved.
Let me know
Jan 17, 2011 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Says lid and won't work
Check the lid switch... sometimes if something heavy or someone sits on the lid, it can tweak it just enough so the lid switch loses contact and will keep the machine from turning on. You can sometimes bend the lid back. Check the lid switch by sticking a credit card between the lid and the switch with the lid closed... does that solve it? let me know.. KEN
May 08, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore elite canyon capacity washer
check out the lid switch ... move it up and down slowing and see if you can hear the lid switch clicking.. lid may not be hitting just right or something... should also be under warranty
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
I get a F error message when the cycle is one minute into the start....
I DON'T KNOW BUT IT SEEMS I HAVE HAD NOTHING BUT PROBLEMS WITH THIS WASHING MACHINE. MINE IS NOW STUCK CLOSED WITH ALL MY SONS JEANS IN THERE, AND NOW I HAVE THE F CODE TOO!.
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
