delta diverted spout is stuck! Can't pull it down but there is no water coming out from shower head. Water comes out in the tub only. Please help! I'm not sure what is the problem and unfortunately, I do not know the model #. It's only about 5 years old. Thank you!
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Who fixes Culligan water softeners and equipment in Sonoma County besides James Fisher and son in...
(More)
Who fixes Culligan water softeners and equipment in Sonoma County besides James Fisher and son in Santa Rosa??
my tub stop will not come out. I believe it is a moen. I can unscrew the top but then nothing. There...
(More)
my tub stop will not come out. I believe it is a moen. I can unscrew the top but then nothing. There isn't a slot for a screwdriver and I can not unscrew it to the right as I would assume. Thanks for any help
after power is applied, the lights are lit for only a few seconds, then the power goes off in the...
(More)
after power is applied, the lights are lit for only a few seconds, then the power goes off in the seat.
bad drainage smell in rooms. i need a diaram of how a stack pipe with aav's should be fitted. please...
(More)
bad drainage smell in rooms. i need a diaram of how a stack pipe with aav's should be fitted. please help
