Question about Frigidaire GLTF1670A Front Load Washer
No cold water, only hot water in tub
No matter which program / temp I choose my laundry always feels hot, so only let hot water into the tub . Help my clothes are shrinking ! Yes, the cold water is turned on !!
  • 641 Answers
Check first the filters on the cold inlet water line (both sides). Then, if problem is still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 02, 2007
Hot water won't run into washer
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected. Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot. Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected. In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
Aug 17, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
Hi.. we'll feel cold after taking bath from? 1. cold water 2 water at 40 c 4 water at room tempreature 3 water at 50c
"we'll feel cold after taking bath from?"
(Let's assume room temperature of the bathroom is 25 c.)
1. cold water
Assuming cold water means below room temperature, for example, 22 c. One taking a bath in water at this temperature would probably feel cold DURING his bath at least at first. However, a cold bath would tend to bring blood to the capillaries under your skin and create a warming sensation. But after you get of the bath tub, you would definitely feel cold unless the room were heated!
3) water at 50c
Most folks would feel quite hot while in the water at this temperature. And after exiting the tub, since the layer of water on his skin would probably still be well above body temperature (37 c), a chill would not set in until the water on his skin cooled down to below body temperature. So if he quickly dried off, he would avoid feeling cold.
2 water at 40 c
While almost completely immersed in the bath water, one would certainly feel warm unless there were a draft in the room, because 40 c is 3 degrees above normal body temperature. For the same reason as stated above (#3), he could escape feeling cold outside the tub if he dried off quickly.
4) water at room temperature
- If I had to select only answer, I would choose this condition that would make one feel cold after stepping out of the bath tub, because:
Upon exiting the tub of water at room temperature, one would certainly feel cold if there were a draft in the room. Even if there were no draft, one would still feel cold, because the water on his skin would be cooler than his body heat (37 c), and cause a finite evaporation of the thin layer of water on his skin, which is a cooling process. The skin's heat would be lost, because its energy would be used to evaporate the water.
Mar 30, 2010 | Scientific Explorer My First Chemistry Kit
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Erratic water flow and temperature from laundry tub faucet..
this is quite possible, the newer units, actually are monitering teh watertemp, as it enters machine, and will either increase or decrease flow of both hot/cold water to maintain what it would consider an optimal temp.. so i would not worry about this issue.
Feb 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
No Cold Water Wash; Only Hot
When doing a hot wash the machine is designed to take both hot and cold water. This is because it can heat the water to your selected temperature but if the water coming in is too hot it needs to cool it down to avoid heat damage to your laundry.
Hope this helps & thanks for using Fixya.
Dec 18, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
