Question about Toshiba Satellite M45-S169 Notebook
Won't turn on - dead dead dead
Checked e-mail this morning. Worked OK. two hours later nothing! The AC adaptor measures 19vdc output (not under load, i.e. unplugged). Little green light(s) on front DON'T light up. For a long time, the ON button has had to be pressed only on the front right corner and pressed rather hard to turn it on. The laptop doesn't do anything using battery either. PLEASE HELP SOON!! Thank you
  • Lalemoreno Sep 02, 2007
    Are you saying the ac power adaptor is bad?
    It doesn't work on the battery either
    Brigadier General:
  • 6,966 Answers
Hi, This sounds like the power supply circuitry inside the notebook. 1. AC Adaptor - OK but if connected to the mains and plug to the laptop, there should be an indicator in the laptop that it is so, per your post none; 2. Battery - doesn't power the laptop; 3. Power Button - press hard and long, not normal. Guess that leaves only the laptop itself. This would involve opening the unit and diagnosing the power supply section which includes the jack, reverse protection diode, smc fuse(s), charging components, power button and others. Probably you should seek the services of a qualified professional though I am getting the impression that you are technically adept likewise. Hope this be of some help/idea. Post back how things are or should you need further information. good luck and kind regards.
Posted on Sep 02, 2007
    Sergeant:
  • 457 Answers
I since the problem is a stuffed battery ort else the power pack has ceased to exist. One thing is the way you have explained it seems the Laptop is ok try and find someone with a another powerpack maybe the battery ok it seems to me the pack has poked? Goodluck I wish all the problems seem simple like yours.
SOURCE:
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
The laptop would not boot up. It was hooked up to an external screen and then a few hours later, there was nothing on the screen. It wont boot up into a POST screen
Dead Laptop?
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Acer TravelMate® C314XMi (G16012) Tablet...
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
HP L2000 Sudden shutdown wont power up power supply good
what makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
Jul 17, 2017 | HP Special Edition L2000 LiveStrong Mobile...
2003 Nissan Pathfinder Bat, AT Oil Temp, Brake Lights All Lit
GET YOUR BATTERY LOAD TESTED ALONG WITH YOUR ALTERNATOR TESTED FOR OHMS VALUES AT THE REGULATOR. ALSO MEASURE THE VOLTAGE WITH ALL LIGHTS, AC, RADIO ON. SHOULD BE THE SAME AS BATTERY OUTPUT.
Jun 16, 2009 | 2002 Nissan Pathfinder
Ac power doesnt work only in battery mode,adaptor output is ok
sounds like the power connector (where you plug into pc) is going bad. try twisting / wiggling connector. pause for a few seconds between twists to give circuitry chance to reconize power input. sometimes there is a green led that will light up when power adaptor is inserted. you can use that as a reference.
Jun 03, 2009 | Computers & Internet
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
2wire 1800hg wireless gateway/router not functioning...
Your power adaptor might be faulty.  Yes, you can measure to have 6 volts.  But due to faulty electronic component in the power adaptor, the 6 volts will be dropped to a very low level due to "loading effect"  when you connect to the router.
I had the same problem but could not find the original power adaptor.  I replaced it with a 3rd party power adaptor.  You must ensure that the 3rd party power adaptor can provide 6V output with minimum 2000mA (2 amperes) and correct connector size.
Apr 07, 2008 | 2wire 1800HG Router (RG1800HG00)
Toshiba Satellite M45-S169 Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
