Question about LaCie (300728U) 250 GB Hard Drive
Drive will not complete the back up
I've backed up my computer once. Was asked to enter my password after most of data was backed up. Did so and HD went on to complete the back up. Now, the second time got a message that the password may need to be changed. OK I hit "continue" and then got "unexpected error" code -8072 and the back up stopped. Tried it twice with same result. What do I need to do? Thanks.
    Novelist:
    Champion:
  • 244 Answers
This error represent no available space to store for backup file.
Posted on Oct 31, 2007
6ya staff
SOURCE:
What do I do when asked to change my password because my existing one has expired?
Once a password has expired it can't be changed because in order to change a password, you must first enter the old existing password and then change it. So what you have to do is re-register. Since you haven't been specific about what the product is I can only answer in generalities.
Sep 22, 2014 | Active Password Recovery Software [email protected]
Password
Hi, I'm not sure if there is a universal password, but if you can remember the Pin number try the following steps.
Power your device off, and then start it up again and enter the correct pin number. If that doesn't work, you will need to try the option to enter your Gmail account credentials so that you can access your device and change your password. (Oh, I forgot you can't access your Tablet)
I think you will have to do a Hard Reset by completing the following steps:
Turn off Tablet Try one of these key combos (each Android device uses a slightly different key combo, but these are the most common).
Volume Up + Home + Power or Volume Down + Home + Power
or
look for a reset button/hole
Release the power button when you see the Android
Choose recovery mode
Choose wipe data/Factory Reset
Choose yes
Tablet will reboot or will ask you to reboot
NOTE: This procedure will delete all apps and data so use it as a last resort.
Good luck
David
Feb 25, 2018 | Tablets & eReaders
Forgot passcode
I think all you can do it reset the device to disable the password completely. If you enter the password ten times incorrectly it will ask if you want to do a complete reset.
THIS WILL DELETE ALL YOUR PERSONAL DATA.
If you can, back up your device using the Blackberry Desktop Manager application before doing a reset. Then you can re-load all your personal data after the reset, instead of having to type it all in again.
Jul 24, 2010 | Cell Phones
How can I resest the device password, because I've forgot them, thanks
thanks
Jul 08, 2010 | Cell Phones
Installed new HD into Dell 1720 Inspiron after getting the 0146 errr code. Once I installed the HD I began the installation of Vista. It almost finished then the screen went back with the cursor...
you need to format the hdd first before you can successfully install Vista.
try booting from cd/dvd by pressing F12 on the Dell screen.
- Select optical disk drive dvd/cdrw and press Enter
- Press Any key to boot from CD or keep tapping the spacebar.
- If you see Windows Setup EMS enbaled, press Enter.
- Keep clicking next until you are asked "Where do you want to install windows?"
- Click Drive options Advance
- Click or select to highlight the partition to where you want to install Vista
- on that same windows, click "Delete" and OK
- Click "NEW" and then click "Apply"
- Click "Format" and then "OK"
- After that, you may now click "Next"
Now windows vista should be installed in your computer and on its last boot, it will ask you to create a profile (username and password).
^_^
Jun 12, 2010 | Dell Inspiron 1720 17" Widescreen...
Computer has been working fine. Now all of a
When system boots press the key to get into BIOS. Usually it is 'Del' Key. Once you get into BIOS, if not asking a password, get into admin menu and set the password option disabled.
If asking for a password while you get in to BIOS and you dont know the password, the only option is to reset the BIOS.
To reset BIOS u've to remove the back cover and remove and re-insert the CMOS battery while the laptop is powered off. After that, power on the laptop and set the bios to normal setting, especially the time. This wont harm any of your data.
Please come back and vote for me if this finds helpful for you. Thnx
Mar 28, 2010 | Computers & Internet
Want to move the Cards and Login information to second computer. How can I do that? Norton 360 v3
You can make Back of the Identity safe
1. Click on identity protection and select manage identity safe
2. enter the password
3. click on Back up Identity safe Data
4. Gave any name, select location as desktop and enter password
once you successfully backed up the identity safe data
5. You can copy the Back up file into nay removable media
6. paste into other system's desktop
7. Click on identity protection and select manage identity safe
8. enter the password
9. Click on restore Identity safe data
10. select the and enter password
11. click on apply or okay
Now you an use the Log ins in second system
Mar 14, 2010 | Symantec NORTON 360 3 for PC
Can' get back on computer
Hi. Is it the bios password or Windows password? If it's the bios jumper 1 on the mother board is the bios reset. Just reset the jumper and all shoul be good. If its windows it may be an administrator password you had when you set up your pc that being the case, depending on how you setup windows you may be able to press ctrl,alt, delete to get to user menu and press enter, alternativly clear the box and press enter.
Mar 31, 2009 | Computers & Internet
Dell OptiPlex GX150 won't do anything.
on the motherboard there is a battery. it looks like a watch battery. there should be a jumper next to it with 3 prongs. move the jumper over to the next prong and start the computer.( it will start but will not come on). turn off the computer and put the jumper back to the first position. start the computer again and the bios will be reset
Mar 28, 2009 | Dell OptiPlex GX150 PC Desktop
Forgot password blackberry curve 8310
May 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
LaCie (300728U) 250 GB Hard Drive Logo
144 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
