Question about HP GeForce4 MX440, (64 MB) AGP Graphic Card
WUPS.DLL issue after fdisk and reloading XP Home
I insterted my XP Home CD and rebooted my computer and it triggered the reload of the OS. I chose to fdisk the main partition first and then it loaded/copied everying to install windows xp home. I answered the questions and when it went to restart it hung. I waited about 5 minutes and did not hear the hard drive so I powered my Desktop down and when I powered it back up it still hund. The second time I powered up itnd I took it into safe mode I saw that it always hung on wups.dll. Any suggestions?
    President:
  • 2,961 Answers
When you finished the installation you must of ticked the part where it says 'do you want windows to check for updates now', as the wups.dll is the file that checks the internet for windows updates. If you cannot get windows to startup correctly, then i would start your system up again with the disc in and either choose repair or reinstall and dont let it check for updates this time as you won't be connected to the net.
Posted on Sep 02, 2007
SOURCE:
Ji case 440
the OS is corrupted, a fact ! deal with that first. reload it yet?
the word laptop or desktop not stated, wow.
Optical drives dead. (super common)
get rid of XP?
stop using it. now.
what is Ji,? (Spanish for laugh, mixed with English case)
what is CASE? (or the computer case is bent)?
use full PC names only. and full model number for help.
XP is a dead OS and virus magnet,
old DVD drives fail.
the drivers in your PC are corrupted, if XP its like normal
why not reload the OS, for the disks Dell gave you.
is this an OLD M440 Dell Precision laptop? my wild wild guess....
or M4400 , SC440, or
the M440 (M means mobile at dell. lap/notebooks, are)
Dell has zero support on M440 and precision.
time to buy PC 2010 or newer, would be 10x more reliable and happy users. do not run XP ever. again.
Dec 31, 2017 | Dell Computers & Internet
The procedure entry point bink set mix bin [email protected] could not be located in the dynamic link library binkw32.dll
The easiest way to fix this is to reload your operating system. Hopefully you have backed up your files recently.
When you are ready to reload the system FDISK the HDD, then boot to the OS CD or DVD ROM and follow the prompts to the end of the reload. Reboot and it should be good to go.
Sep 06, 2012 | Disney Interactive Cars 2 The Video Game...
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
Have reformatted and am trying to reload xp on a
Probably a dirty or scratched disc. You can borrow another and still use your own serial number
Feb 27, 2010 | Microsoft Windows XP Home Edition
IBM Lenovo t60, the logon user interface DLL
To wipe and reload you don't actually have to log in. You just need to set first boot option to CD, insert the XP disk, and reboot the computer. All the steps from there on out are explained on the screen.
I hope this helps :)
Oct 14, 2009 | Lenovo ThinkPad T60 8742 Notebook
Entry point apsCreate MIB could not be located in the dynamic link wlanapi.dll
I don't see a question but I assume you are getting this message from your OS when you boot the computer. Uninstall the device shut down the computer and reboot then reinstall the device. This should reload the .dll file that is causing you problems.
Oct 12, 2009 | D-Link Computers & Internet
Unable to reinstall windows xp
try it again with the bootable floppy disk... if you have the option use fdisk /mbr and then format the computer and reinstall using the cd you have. the fdisk /mbr command will get rid of any virus residing in your master boot record.
May 24, 2009 | Microsoft Windows XP Home Edition
Can't reload XP
Depending on the age of your PC it may have Dell automatic recovery
During startup at the Dell Screen hold down the CTRL key and tap F11 twice
It may display the Dell Recovery from which you can set your computer back to factory settings
Please note all your files will be deleted
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Acer aspire 5715z/5315, turned laptop on took time to load up wasnt responding,restarded laptop then it wouldnt restart then i turned it of manually, turned it back on,screen acer back ground in the bottom...
Reboot your system-press and hold F8 until you get a list of options-select Safe Mode-enter.Your system will run in Safe Mode,giving you a dropdown list as it progresses-check where it stops.In this way you can establish wether you have a corrupted or incompatible driver and which {Graphic ie} stop the system.You will have to reload the OS to solve the problem.If you cannot even boot into Safe Mode,your drive very likely crashed.Happy landing.
Jul 22, 2008 | Acer Computers & Internet
Error no 0x80070003 appears when trying to install Windows update.
Click on the start button, click run
at the run window type the following:
sfc /scannow
now your windows system files will be checked for changed, if they are changed a fresh copy of the files will be copyed from the windows cd.
Note: you must have the original windows installation cd in the cd/dvd drive.
Jan 04, 2008 | Microsoft Windows XP Home Edition
Open Questions:
ROBOSCAN customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This ROBOSCAN USA phone number [+1:8OO:,:8O31069] is ranked #2 out of 2 because 7,728 ROBOSCAN USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the ROBOSCAN USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, ROBOSCAN USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ROBOSCAN USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ROBOSCAN USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ROBOSCAN USA Calling ROBOSCAN USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ROBOSCAN USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ROBOSCAN USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ROBOSCAN USA's phone numbers against each other. Contacting ROBOSCAN USA in General While I8OO8O31O69 is ROBOSCAN USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach ROBOSCAN USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ROBOSCAN USA.Anita
Oct 17, 2019 | Best Computers & Internet
Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...Avast support pHoNe #{+1-888**499**5520 how to get...
Oct 17, 2019 | Computers & Internet
See all HP GeForce4 MX440, (64 MB) AGP Graphic Card Questions
Computers & Internet Logo
249 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
