Question about Soleus KY-34 Portable Air Conditioner
Soleus Heat/Air/Dehumidfer Unit
I cannot get my Soleus LX-140 to turn on. I plug it into the socket and can get the timer to come on and off but cannot get the air/heat to come on. I have contacted Soleus and they tell me I will have to send it back to the company. I wonder if there is someone other than Soleus who can repair my unit. Soleus told me that Sears might be able to help but I called Sears and they cannot. Do you have any suggestions?
I have had a soleus wall unit since 2005.
It is a wall unit in my apt...I have never had to use the heating part...but use the cooler part alot.
I can not figure out if that lil raindropis for adding moisture to a room...or is it to remove moisture from the room?
My apt always has to much humidity, so I do use that setting quite often, but can't tell any difference in the humidity gage.
Who knows anything about using one of these.
Posted on Apr 25, 2008
  • Peachyyy Apr 25, 2008
    I did email this company a few days ago but didn't get an answer back, makes me thing no one is interested in helping here???
Where is the fuse located on my soleus air conditioner lx-140 house unit. I want to replace it.
PDF]download manual - SoleusAir
www.soleusair.com/Manuals/2013%20Manuals/.../PH4-13R-01_Manual...
Thank you for choosing a Soleus Air Portable Air Conditioner with Heat Pump ... owner's manual will provide you with valuable information necessary for the
Aug 17, 2015 | Soleus Heating & Cooling
How do I find an exploded view of a LX-140?
SOLEUS PORTABLE Parts Model LX 140 Sears PartsDirect
Sears has a diagram that if you click on it will expand it and you can pan around. If that isn't sufficient, you might try emailing the distributor directly: email to contact@soleusair.com
Jan 16, 2015 | Soleusair LX-140 14,000 BTU AC and 14,200...
Can a SoleUSAIR be recharged
Yes they can be. But what makes you think that it is low on a charge of R410A?
Jul 01, 2014 | Soleus LX-140 Portable Air Conditioner
Is a soleus lx-140 portable air conditioner good?
If it's a real good price, and you have enough technical skill to perform the much needed & required regular maintenance for operating (especially in dusty locations) or know someone capable of said task then I say it's worth it as a menopausal woman with constantly changing internal temperature. I bought mine refurbished from 3Gorillas.com (link below).
3Gorillas com Great Products Great Prices Free Shipping Every Day
If you're not technically savvy then they may have a different model for you, but I did my research. They definitely have the best prices for appliances.
~cheers
Jun 22, 2014 | Soleus LX-140 Portable Air Conditioner
How to fix E4 error
check the water tank flipper if broke it will directly cause the unit to not function and the E4 message will apper on the display screen.
May 26, 2014 | Soleus LX-140 Portable Air Conditioner
Have a Soleus LX-140 portable air conditioner. Water was leaking out the right side of the machine. Opened the casing and found a clear hose, one end attached to the plastic tray above the condenser and...
I have an LX-100, and had the same problem, so I am guessing that the designs are similar. There should be a pump in the condensate pan at the bottom of the unit -- on mine, it was near the front, right next to the overflow float switch. There should be an outlet on top of the pump, which is where the hose needs to be attached.
It looks like the pump pushes condensate up into that plastic tray, which lets if flow over the heat exchanger, both cooling it and evaporating the water. With the hose detached, you're probably noticing degraded cooling performance and a lot more condensate in the holding tank than there should be. At least, that was the case for me. Good luck.
Jul 05, 2011 | Soleus LX-140 Portable Air Conditioner
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Jun 17, 2010 | Soleus LX-140 Portable Air Conditioner
Soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
May 19, 2009 | Soleus LX-140 Portable Air Conditioner
Soleus KY-34 Portable Air Conditioner Logo
337 people viewed this question
Top Soleus Heating & Cooling Experts
Dennis Boxerman
Craig Butler
Craig Butler
Gil Shultz
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
