Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
Cable TV connection
By ulex on Sep 02, 2007
New home where cable TV jacks were not connected. Using the coaxle cable installed during construction, I added screw on F connectors and was able to receive basic service to each of the TV's. However, some of the channels are not coming in clearly....different channels in different rooms. Any thoughts as to why?
Solution #1
posted on Sep 02, 2007
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3794 votes
A couple of possibilities:
1. Line loss, some of the cables might be too long, shorted, loose ground, not connected right;
2. Splitter - passive splitter, you might be better off using a distribution amplifies (with gain control pref);
3. RFI - TV interference from external sources.
Hope this be of some help/idea. Post back how things are or should you need further information.
Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
resistor smoking on vertical
Answer
Bush IDLCD32TV22HD green tinage to screen on shadows
Answer
what buttons do i press to play it
Answer
the word video won't leave the tv screen. Advice: push the display button. Q: which one is the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
