The motherboard is no spring chicken, so there is a good chance that it has given up. Check the capacitors around the CPU socket. They are between the socket and the back panel.They should all be flat or dished inwards. Although there are a couple in the area of the power plug. This is the first place to look as it is an area that has been disturbed. If they are not as I have described then you could replace the blown ones but there is no way of telling what other damage has been done.
Thanks for the input, but the warm capacitators are in the bottom right, next to the front panel pin connectors, non of the capacitators seem to be broken in any way. They look like all the others.
They will get warm when being used- they are basically a battery, used to smooth power supplies. That is, they remove spikes that can occur when a switch operates. Have you tested the board with the old PSU? Just because you have bought a new one doesn't mean it is perfect.
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
I forgot to mention that the capacitors C3K1,C3K2, C3K3, C3K4, and C3K5, where quite warm after the incident
