Question about Panasonic PT-51G53 51" Rear Projection Television
Panasonic pt-51g53w set starts to power on then clicks and shuts down, how easy is this to troubleshoot and fix?
  • Anonymous Jun 26, 2008
    I do have the same problem with the set turning on then after a couple on minutes it snaps off with a pop. In the past if I just smacked the top of the set it would pop back on. Now however that is not working and the set just comes on with a thin twisting line in the middle of the set.I still have sound just no picture. Could this be the way the TV was wired this problem only started after my set was rewired by the cable service guy?
  • 398 Answers
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Posted on Sep 02, 2007
Panasonic PT-56HX41 - I have a red light (power) that blinks 3 times and then nothing. The TV went super bright and then the display and audio went out. I plug it in and I click on the power, I then hear a...
The three blinks is indicating that the convergence circuit has failed and shut the set down. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the Parts and the CD with instructions for the repair
Aug 06, 2011 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I have a panasonic pt 4743g that just shut off. I
Thats the error code for the convergence circuit shutting the set down The PT4743G uses the PT53WX53G convergence repair kit which is available from www.tvrepairworld.com the kit contains the parts and the CD with detailed repair instructions.
Nov 21, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No sound, no picture, power light blinks
i have a model #pt-53wx42f when you first turn the t.v. on it gets shakey and distorted then it shuts down and the power button light starts flashing
Sep 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red and Green Spots
Not a fix for do-it-yourselfers, but check with Panasonic as there is a new fix. Requires tech to come and reprogram the eprom (I think).
Cheaper than a new optic board.
Jan 03, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-51g53w
Usually, in the Panasonic projection sets that start but then shut right back off, one of the convergence IC's has shorted out and is drawing too much current. When the TV is turned on, the computer senses the extra current and shuts the set back off. The set should be serviced by a qualified tech familiar with Pansaonic projection sets.
Aug 28, 2007 | Televison & Video
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51G53 51" Rear Projection Television Logo
344 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
