Question about Emerson (33416-78414) Fan
Emerson Fan The motor runs but the blades don't spin. What part do I need?
  • 104 Answers
Check the set screw of your fan blade. tnx
Posted on Jan 28, 2008
2 Suggested Answers
keithd2704
  • 56 Answers
SOURCE: NuTone LS100 fan is squiling when it runs.
Sounds like it may actually be the bushing pack inside if the motor. Spinning the blade by hand is not going to spin it fast enough to hear the problem. If the unit is new, I would recommend returning it for exchange of a new unit. If it more than 1yr old, it's out of warranty and will be cheaper to just replace it rather than repairing it.
For less than $100 you can buy a newer, more efficient model. Depending on the size of the room is how should judge what unit to buy. An under sized unit will not pretty much nothing, except make noise and remove some of the steam. Remember to buy a fan with the lowest SONE rating as it will have the highest quality motor housing and best air removal.
Keith
Posted on Feb 28, 2011
Fan needs a push to spin
Check the capacitor in the cup of the fan. It's usually a black box with wires going to the pull chain switch.
Dec 03, 2013 | Emerson CF712AW Pro Series Fan
What are the different types of fan blades available?
There are few types of fan blades that include:
Traditional
Industrial
Decorative
Outdoor
For more details on these types of fan blades, check out this website: http://www.ehow.com/list_8026115_fan-blade-types.html
Feb 07, 2013 | Emerson Fan Motor & Blade - 1/6 HP
How much does the Fan Motor And Blade 1/6 H.p. 460 Volt cost and where can I purchase it online?
Price for the Fan Motor And Blade 1/6 H.p. 460 Volt varies from site to site, but it generally costs around $60. You can purchase it at Ebay: http://www.ebay.com/itm/Emerson-Fan-Motor-and-blade-1-6-H-P-460-Volt-/251062473352
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Vornado Circulating Fan - motor will run but blades will not turn.
    Does the motor spin, but the blade is not turning?
    The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
    Jun 27, 2010 | Vornado Circulating Fan
    Motor hums but blades don't spin
    It should have something in motor block blocking the motor to turn.
    when it is OFF position ,you try to turn it by hand to see if it spins freely or not ? You may hear a sound of friction that blocks the motor. if this is the case try to find a local electrical expert to unblock the motor..
    Good luck.
    May 04, 2010 | Emerson (33416-78414) Fan
    Was vacuuming coils/bottom of fridge and my brush hit the fan and now fan is not spinning. Does the fan always spin or only when called for??? HELP HELP
    If the compressor...the black can in the back...is running then the fan should be running...
    if it is not running when it should be, check the fan baldes, you may have bent one or more of the blades and now the fan is stuck because it cannot turn...
    If so, just bend the fan blades back stright so they do not hit anything...
    heatman101
    Apr 25, 2010 | Refrigerators
    Fan blade won't turn, but will slowly turn if given a push. What is the problem? How do I fix it?
    Replace the fan motor capacitor. If that does not correct the problem you will have to replace the fan motor.
    May 12, 2009 | Goodman CLQ36AR49 Air Conditioner
    Emerson (33416-78414) Fan Logo
    167 people viewed this question
    Top Emerson Dryers Experts
    Steve Allison
    Steve Allison
    Angel Joseph Jr.
    Angel Joseph Jr.
    Tom Chichester
    Are you an Emerson Dryer Expert? Answer questions, earn points and help others
