Question about Nokia 3230 Cellular Phone
Nokia 3230 My Nokia 3230 when opened, lighthed-up and got sounds but no display. Per suggestion of ZCHLUGGER, i opened the case (housing) and tinkered on the LCD and its connection to the mainboard. Detached the LCD connection from the mainboard, cleaned it and reconnected again. But it didnt work. The LCD just lighted-up alright but just the same, no display. What should i do next? Somebody out there, the EXPERTS, got more suggestions or recommendations what to do next?
  • 11 more comments
  • Burd Sep 02, 2007
    Yo, BDEATH! This is BURD who posted the problem with my Nokia 3230.
    Can you direct me where to find that Flash file? And of course, how to reprogram and reinstall same. No, i wont do nothing on my celfone. Thanks.
    Burd
  • Anonymous Dec 10, 2007
    My phone is giving these messages when i m trying to do "*#7073#",it is not giving any options to press ok or further ok to give 12345 code to fromat my phone.As and when i switch on my phone after a switch off it is giving a "SIM Card not Valid" message.I have tried with many sames so as to make sure whether it is a problem in my SIM.I am sure it is not a problem in my SIM.It is working to find out my IMIE no.
    Please assist me in this regard.My phone is about one year old.
  • chaolol Dec 10, 2007
    I am using Nokia 3230.
    When i switch on my phone it is not moving further forward from NOKIA msg and it is giving some sounds.
    I am able to get my IMIE no by using the code "*#06#".
    I am not able to format ny phone even using 3key boot trick.
    I am not able to use the code *#7073# because it is not giving me any options to give Ok or something else.
    I am not even able to restore the factory settings also,by using the respective code.
  • Anonymous Apr 04, 2008
    not on the bluetooh
  • Anonymous Apr 16, 2008
    My set was workinhg fine untill it statred returning 'App. Closed' error and 'Memory Full, Try to delete some data' errors. I sounded it right to restore its factort setting, but after doing so nothing is coimg on display. Mobile seems to be powered on, but nothing appears on screen as LCD does not get powered off. What can be the reason? any help regarding this problem will be welcomed.
  • Anonymous Jun 19, 2008
    can`t turn on
  • milindgrt Aug 15, 2008
    After Switch on The the screen becomes white
  • hitesh_tomar Oct 07, 2008
    i have same problem, in my nokia 3230 , when i on the mobile, no display is screening.
  • Khushalduth Oct 13, 2008
    hi i'm akshay from mauritius, i have a problem with my nokia 3230 and it is that when i am inserting my memory card, it ask me to format it, when formating is completed, it ask me to change the name of my memory card, i select the name and when i press 'ok' it tells me 'OPERATION FAILED'. My nokia 3230 is not accepting the memory card, so how can i fix it up?
    Akshay
  • kihua Jan 20, 2009
    when i start my mobile it shows the nokia sign but no sound comes from it after sometime there will be ablank screen without any nakia sound
  • netke15 Jan 20, 2009
    when i turn on my phone, my phone is start up failed to start up
  • Anonymous Mar 10, 2009
    how to format 3if handpone is swicth off
    how to format if handpon is off
  • 58 Answers
Try to find a 3230 flash files and just flash it. If the display, light for a momment then it is not a hardware problem but software. need to reprogram or find the same flash program files and reinstall on it. If you don't know how just tell me.!! but don't let nothing to erase your cell phone stock program version..
Posted on Sep 02, 2007
  • Marios Kyriakou
    Marios Kyriakou Sep 03, 2007
    Well at first find your imei number. by pressing *#06#. If The display still dead then remove your battery and it should be underneath on the nokia's chassis.. If you find it go here http://www.lur.nu/unlock/nokia_eng.php
    I will wait you reply.
What is 3key boot trick
Posted on Sep 30, 2008
I nokia phone sccreen flicks gets off again
Posted on Sep 21, 2008
    Problem Solver:
My 6680 was ran out of battery while formatting,,and now it doesn't starts only shows up the NOKIA logo and nothing more. is there any way to solve this problem manually?pls help me..thanks
Posted on May 26, 2008
Try formatting phone memory..
press green-*-3-power button....
wait until phone starts and shows formatting process..
Posted on Dec 21, 2007
Yo, BDEATH. Greetings from the Philippines. Thanks for the #2 solution. I already followed the instructions on http://www.lur.nu/nokia_eng.php. But how can i see what appears on the LCD...it has no display whatsoever. It remains lighted-up...but no nothing. I think..it's time to visit the cell phone shop. What do you think? Any more suggestions? By the way, are you a technician...mobile phone repair technician? I might ask you some suppgestions one of these days...also about mobile phones. I still have old model, low end cells which I think worth tinkering with. Repair shops charged us exorbitantly...its expensive here, you know. What do you say?
Posted on Sep 04, 2007
SOURCE:
Headset icon is being displayed in Nokia 3230. so I am not able to listen any voice when i call. Please suggest how to remove this icon.
hai, your problem regarding ribbon cable problem, for this model got 2 pcb, Main and sub, sub pcb is for display board. If your have complete tools, you can just but ribbon cable only, replace it, but better you change all sub pcb for display, normally complete coming with joystick together, but without camera unit. Just replace it. The cost i'm not sure.
Aug 04, 2010 | Nokia 3230
Display problem in nokia 3230
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Mar 15, 2010 | Nokia 3230
My nokia 3230 having hanging problem..wat is da problem
Might a chance of virus infaction. Please scan your mobile by updated mobile anti-virus. If not done then i suggest you please format the phone & install the updated version. Thanks.
Mar 02, 2010 | Nokia 3230 Cellular Phone
Display problem
Its power strip problem Replace it.
Sep 23, 2009 | Nokia 3230
Display not working in Nokia 3230. However , I can receive call
The Display circuit is broken, The only solution is to change the LCD-display.
Please vote!
Jul 03, 2009 | Nokia 3230
Nokia 3230 started then open menu then select setting option then select phone then select general then select orignal phone setting then display a code box that is i forgot help me
Oct 22, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 camera problem
It may due to bad display........sometimes it happen when the mobile fall down..It works properly but camera and video may face problem..
Regards
dilipbagdi MCP, MCDST, MCITP, MCTS
Aug 27, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 no sound
seems like the buzzer is the problem since tones don't work but the ear piece is fine..try changing the buzzer or cleaning the contacts of the buzzer,.try yourself or bring it to a cellphone specialist
Sep 11, 2007 | Nokia 3230
White light
Phone + Water = Death Most cases of liquid damage cause the phone to die. Replacing the parts of the phone usually exceeds the price of a brand new one. I can only wish you the best of luck in repairing the phone.
Feb 28, 2007 | Nokia 3230
Solution
just press *,3 and callbutton at a time then turn on phone with press of three buttons untill nokia on display then remove only on/off swicth and press *,3 and call untill formating on display. ofter formating complete the phone will be restart and comes in inset simcard. ready to use normally.
Jun 27, 2006 | Nokia 3230
Nokia 3230 Cellular Phone Logo
472 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
