Question about Panasonic SC-HT740 System
The DVD player no longer works
The DVD player displays DVD 893. The customer support tech said to hold the on button and the >=10 button at the same time and now nothing on the system will work. Does anyone know what the 893 code means?
  • Anonymous Apr 03, 2008
    I am having the same problem and holding those buttons doesn't fix anything. The player is taking a long time to process anything that I am telling it to do.
  • Anonymous Apr 03, 2009
    same thing... dvd 893 and no response aside from the power button.
Try this - while in DVD mode (no disc) hit the stop button on the unit and the "10" button on the remote. It might work as this initilizes the unit.
Posted on Jan 09, 2008
SOURCE:
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
Sony blu-ray player BDP-S280 unlock
Turn on the Sony Bluray disc player - BDP-S280. Press and hold the play button for 10 seconds. It should display unlock on the front panel display. You can lock by pressing and holding the play button for 10 seconds again.
Oct 20, 2012 | Sony DVP-NS330 DVD Player
Trying to program my dish network remote to run my Hitachi dvP543u DVD player. None of the Hitachi codes that dish network tech support has, work. Please help! Thanks in advance!
This is what is called a power scan this should resolve the issue for you.
Hold down the clear "AUX" button until all four of the clear buttons at the top of the remote are lit, press 222 then press pound (#). Then hold down the clear "AUX" button until all four of the clear buttons at the top of the remote are lit. Next press the large red power button then press and release the channel up button once per second until the DVD player powers off, once the DVD player turns off hit pound (#).
Daniel Busa
DISH Network Customer Service
Nov 26, 2010 | Hitachi DVP543U
I have dish network and i want to put my dvd RJ Tech at my remote control but i can't to find the code for this dvd can you help me with this ? My dvd is a RJTech RJ800dvx thks
It would be our pleasure in helping you with this. We currently do not have any codes your RJ Tech DVD player; we would recommend performing a power scan. A power scan determines if there is a code that will operate your RJ Tech DVD player.
Power scan instructions:
Step 1:
Press and hold the DVD/VCR mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 17, 2010 | RJ Tech RJ-800DVX DVD Player
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Oct 11, 2008 | Panasonic DMR-ES35VS
Dvdvcr2 displaying SAFE
Hold down the "INFO" button on the remote for 5-10 seconds and this will clear the "SAFE" mode.
Jul 18, 2008 | Samsung DVD-R130 DVD Recorder
Stuck in 'set 1'
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Jan 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Wont read disc-error message HO7
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Panasonic SC-HT740 System Logo
446 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
