Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Superba kitchenaid fridge not very cold, freezer is fine
Our Superba Fridge isn't as cold as the computer indicates. We can set it to 33 or up to 40 degrees, but the fridge is not that cold. The freezer side is fine. Any tips? p.s. we had the motherboard in the computer replaced, and it was better for awhile, but isn't cold enough now.
  • Anonymous Mar 23, 2014
    The fridge turns on but the fridge and freezer won't get cold
  • 291 Answers
Do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Posted on Sep 02, 2007
Kitchenaid superba ksra22fkss00 side by side fridge. The freezer temperature too cold.
Even though the freezer thermistor passes the test, it's bad. The test only sees if the thermistor is open circuit or grounded. These thermistors can send bad information to board. Replace the freezer thermistor and I think that will solve your issue. Good Luck
Aug 27, 2017 | KitchenAid Refrigerators
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
Kitchenaid Superba Model KSRG22FKWH04, stopped, lost the food in the freezer, fridge is not cold. What is wrong. Lost my job and can't afford a new fridge.
are the lights on and if so the power is ok . can you hear a clicking noise . if so it can be the compressor trying to start . and inside the freezer you should be able to hear the fan and under neath also ther is fan that should be going ck for a clean coil .. mm hopt some of these help you .. mm
Oct 14, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
My refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Sep 11, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
577 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
