Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Red lines there are red vertical lines on my tv. we just changed the bulb.
  • oompa loompa Sep 02, 2007
    nevermind, the digital optical cable was unplugged. but, thanks anyway. you really have been very helpful and timely. thanks again.
    Sergeant:
  • 279 Answers
That sounds like a bad convergence board, they cause red lines like that when they go bad. Lemme see if I can find some specifics on your model, and getting parts for it.
Posted on Sep 02, 2007
SOURCE:
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
Red line across the top of the screen. bulb was just replaced
HELLO,
IF YOU HAVE A SOLID RED LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I HOPE THIS WILL HELP OUT IN RECTIFYING THE FAULT AND DO TAKE CARE IN SOLVING THE PROBLEM , BECAUSE THE TELEVISION CONTAINS HIGH VOLTAGE....
May 13, 2011 | Televison & Video
Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
May 27, 2010 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
RCA DLP/HDTV Vertical Lines
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Dec 19, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
