Computers & Internet Logo
A
Anonymous Posted on Oct 04, 2017
Imac bootmgr is missing, ctrl - alt- del wont work . tried booting from disc to no avail. tried doin all the button combo , been at it all day . its a pre 2009 imac if that help and i installed wndows 7 with boot camp and now this , nothing seems to happen apart form the msg bootmgr is missing , press ctrl-alt-del to restart which doesnt restart it :(
tech you
Level 3:
Master:
  • Computers & ... Master 439 Answers
  • Posted on Oct 04, 2017
tech you
Level 3:
Master:
Answers
439
Questions
Helped
67431
Points
1177
Hi this is linda am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
2 Related Answers
Florin
  • 733 Answers
  • Posted on Feb 04, 2010
SOURCE: Advent 4490 when trying to boot get the message
the easyest way to fix this issue is to reinstal your O.S. this error have two reasons:
1.you erase something in windows folder.
2.you tried to instal a O.S.
Anonymous
  • 266 Answers
  • Posted on Dec 07, 2010
SOURCE: bootmgr is missing press ctrl+alt+del to
If your Windows 7 or Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows DVD handy.
If you don't have one, you can create a Windows Vista repair disk using our guide.
Boot off the Windows Vista DVD and then click Next at the first prompt:
You should see a link in the lower left-hand side for "Repair your computer"
The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.
Click the first link for "Startup Repair"
The installation process will repair the system, and then prompt for you to reboot.
Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
BOOTMGR missing
If you have the operating system replacement disc thaT CAME WITH pc, that is what you are going to need. that file is what is missing that initiates the boot
3answers
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
2answers
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Bootmgr missing
hello,
please try with a liveCd (ubuntu/windows)after that it should boot the OS you want to instal.
2answers
BOOTMGR IS COMPRESSED
After the msg is displayed,
Press Ctrl+Alt+Del to continue Try to boot via the Bootable disc, boot to safe mode via the disc and try the folowing
go to dos and try
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
If the above process doesnt works then try,
"Click 'Repair my Computer'
At the prompt to select your OS installation, click the button that says 'Load Drivers'. This should bring up a explorer-style drive browser.
Then just right-click on the drive you tried to compress, and deselect 'Compress this Drive', which should still be ticked on. Hit apply, and apply to subfolders/files.
Got a bootmgr is missing press ctrl+alt+del to restart don't have a Reboot disc
You can try to Repair your Windows using the Windows installation CD (for Repair choose R when prompted). You can let the automatic repair to try and fix it, if that doesn't work upon restart reboot and start the Repair again, but this time select Command Prompt or Console and put in "bootrec /rebuildbcd" without the quotes. If you don't have Windows installation CD you can try downloading Hiren's Boot CD and try to fix the bootmgr with the utilities from the disc: http://www.hirensbootcd.org/download/
4helpful
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Grand Canyon Tech
Grand Canyon Tech
