Question about Flat Panel Televisions
Panasonic TH-42PX25 Plasma TV
My TV has sound on analog channels but no picture, and has high def picture but sometimes no sound. When I am experiencing high def picture but no sound, if I turn the power strip that the tv is plugged into, off and then on, I get picture and sound. I have programmed the channels about five times with no change on the analog channels. This tv is about 3 years old and had an audio-video module replaced about four months ago. This was due to a problem where the tv sometimes got no channels or sound for a couple of days at a time. The new module fixed that problem. Any help?? Thanks, Ron
  • 579 Answers
SOURCE: ESA 42 Plasma picture problem
The power supply is having difficulty. The typical cause is underated electrolytic capacitors. I would examine all the caps (round cylindrical cans) in the power supply and see if any of them are bulged. Not a bad idea to just replace all of them with better rated parts.
These type of caps have all kinds of specs. Not just voltage and capacity, but also temperature, case size, and obtuse stuff like dissipation factor. Most all power supplies use switching type designs that run at serious frequencies (not the old 60 hz - more like 50khz) that stress out these electrolytic caps and many circuit designers (or their cheap bosses) don't specify the better parts. Replace them with the same capacitance, but higher voltage, and higher temp parts (hopefully they will not be too big physically).
Ya, I know you paid $$$ for this TV and they scrimped on cheap parts. Yup, the more expensive a product is, the more pressure the bean counters put on keeping the price down.
Hope Ya Fix It.
Posted on Feb 12, 2008
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Posted on Apr 12, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 193 Answers
SOURCE: Panasonic Viera Plasma TH-42PV7HS- Shutting down
Posted on Dec 20, 2008
  • 51 Answers
SOURCE: th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Posted on Dec 15, 2009
  • 8457 Answers
SOURCE: I must turn on and off multiple times for picture
Ur Tuner signal board have problems,must be change.The problems u discribing,only two boards cause this Power or Tuner boards.
Posted on Mar 30, 2010
Testimonial: "Solid answer. Thanks chu."
0 characters
1 Points
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Flat Panel Televisions
How do I retune my Panasonic Viera TV?
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Th-42px25 red picture, no blue or green
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Low def pictures on high def flat panel
do you have your video pluged in to the tv or any thing elc if so unplug the video any see if that work or it could be your ampifier let me know how you get on thanks
Jan 03, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Flat Panel Televisions Logo
313 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
