Question about Durabrand DUR-1700 Portable DVD Player
Battery not charging
Try to charge the battery and it won't. Does this mean it is completely dead?
  • blondie29 Dec 14, 2007
    Battery will not hold a charge for longer than 15 or 20 minutes even after being plugged in for 12 hours
    Problem Solver:
  • 12 Answers
Try connecting the Adaptor directly to the battery and charge it for 4-5 hrs and that should work...
Posted on Sep 28, 2007
  • shauna
    shauna Jun 10, 2014
    how is this done?
I have an 03 Chev malibu. I just put a new battery in it. She won't start without a boost.runs fine afterwards.if I let her sit for a bit I will need a boost again..please help
New battery could be faulty or alternator not working.
If nothing happens when you turn the key,to check battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested.If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
the link below explains a complete diagnosis,
press the helpful button
Engine Won Crank or Start
Jan 19, 2016 | Cars & Trucks
My laptop won`t charge unless it`s dead and in an outlet I have not used yet with my laptop
Go to control panel, click on Pen and Touch and follow the instructions. Click on the battery icon, you will see your power options, check on each one to set your power options, I suggest you set it to battery saving mode or any mode you prefer.
Nov 07, 2013 | ASUS Computers & Internet
We have a 2003 yukon denali xl. we have a signal saying battery not charging. we replaced battery and alternator. still won't charge. truck goes completely dead. no lights, radio anything. what el
I'll try to help, everytime something gets replaced on these yukons, that circuit needs to be RESET ! Is there a reset button, on your steering wheel, to reset a variety of functions ? , check owners manual, or call your dealer for better advise
Feb 15, 2013 | 2007 GMC Yukon XL Denali
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My COBY NetBook can't switch on. What is the main reason cause by the netbook? Any solution to solve it?
The battery could be dead or completly dead so that means it won`t hold a charge. The way to fix it is to replace the battery. But this might not be the exact reason though.
Jul 23, 2011 | Coby PC Netbook 1ea
What thus mean condider replacing your battery in dell vostro 1510
Means that you "try to change the old battery" of you laptop.
Regards.
Jun 13, 2011 | Computers & Internet
How to charge when battery already dead
The Kidizoom is a camera, not a battery charger. If you wan to use rechargeable batteries, you'll have to charge those batteries in a separate, appropriate charger.
If by "dead" you mean a broken, defective, or past end of life battery, then there is nothing you can do to charge it again. If you simply mean a completely drained battery, put it into an appropriate charger and charge it following the instructions for that charger.
NEVER try to charge a non-rechargeable battery.
Jan 22, 2011 | Vtech Kidizoom Digital Camera
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Durabrand DUR-1700 Portable DVD Player Logo
94 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
