Question about RCA 27F530T 27" TV
RCA 27V513T 27" tv problem
The remote is dead. the only button on the front of the tv that works is the power button. it comes on but is locked on the video screen. the menu button does not respond when pressed on the front of tv?
  • hcrebo Nov 10, 2007
    The remote control will not operate the tv. The menu button, volume contol (up/down) and the channel buttons (up/down) would turn the tv on/off when pressed to increase/decrease volume or channels. The tv will now not turn on no matter which button is pressed. A universal remote control was tried with no effect.
  • Anonymous Apr 30, 2008
    TV turns on and off without pushing any buttons
  • 73 Answers
SOURCE: password
If I knew the model number I could tell you where to find your manual. I'll give you a link to the website that can help find your manual at the end. If you haven't already tried here is another method that may work.
US V-Chip TV Rating Limit
The V-Chip TV Rating Limit lets you decide which TV programs can and cannot
be viewed.
To set TV programming limits:
1. Choose Parental Control from the MAIN MENU. If Parental Controls have
previously been locked, you must enter your password.
2. Highlight and select US V-Chip. Then select V-Chip TV Rating.
3. Once you get to the V-Chip TV rating limit screen, use the arrow buttons
and OK on your remote to change the status of a TV program rating or
content theme from View to Block.
4. For TV rating limits to take effect, lock Parental Controls by accessing the
Lock parental controls menu.
The following sections give you more details about how to change the status of
TV program limits.
Note: If you forget your password, follow step one above to get to the
password entry screen. Then press the VOL+ and CH+ buttons on the TV's
front panel at the same time for at least 8 seconds. You will receive an
on-screen message that Parental Controls have been unlocked once y
Or try this link to help find your particular model number and download your manual. http://support.rca.com/index.html
Posted on Jan 04, 2008
SOURCE: RCA Model 27V513T FPA Lock On
hey i have the same problem only i don't have a remote and i locked my tv out of my own stupidity. its model no. is 27V512T if you're any good with chips mabye you figure out a way to reset the tv.
Posted on Feb 23, 2008
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
bhur
  • 85 Answers
SOURCE: FPA LOCK ON MY RCA TV MODEL 27V513T
go to menu of your remote and unlock the fpa
Posted on Jun 11, 2008
  • 864 Answers
SOURCE: How can I input my sylvania 27"
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
Posted on Jul 29, 2009
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
Dec 14, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
Rca no signal
check thet rca video is on the video port and rca sound on the sound port alternatively choose screen mode with remote
Jul 16, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
How do i manually reset my rca tv model 27v513t without a remote?
To reset it to its factory settings, you must have its original remote control. A universal remote won't go.
Nov 11, 2013 | RCA 27F530T 27" TV
MODEL #27V513T
You must have its remote control to unlock it.
Jan 23, 2013 | RCA 27F650T 27" TV
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
May 26, 2008 | RCA 27F530T 27" TV
Parental Lock
Without an original remote, I'm afraid my friend, not much
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
Jan 17, 2008 | RCA 27F530T 27" TV
RCA 27F520T TV
Models: 24V511T, 24V510T, 27V512T, 27V513T, 27V520T, 27F520T, 27F50T, and 27F634T
TOPIC: Set comes on by itself
Symptom: When the set is first plugged in or after a power interruption the set comes on
Cause: Set was not taken out of factory mode, or has returned to factory mode
Cure: In the service menu go to setting FAC07, then change the value of OPTM2 to “00”
To enter the service mode simultaneously press “Volume Down” on the front panel and “Info” on
the remote control.
Use the original TV remote for the instrument.
Press “7” on the remote to enter factory menu 07. Use the channel down button to scroll down to
OPTM2, then use the volume buttons to set the value to 00. Press the “Sound” button on the
remote to exit the factory mode. DO NOT turn the set off until the screen displays “OK”.
Sep 12, 2007 | RCA TruFlat 27F520T 27" TV
Rca tv 27V513T
If the TV is in "parental lock", then it will not respond to the buttons on the front of the TV. Get a cheap universal remote control, program it for RCA, turn the set on and go through the menu to unlock.
Jun 18, 2007 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
262 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
