Bought new v3 motorola razor - charged for 24 hours inserted sims card still said low battery so I took the sims card out to put that in my other phone to take to work - came home inserted sims card back in new phone and now all I get is a blank screen - any ideas
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockspot.com/motorola-motorazr-maxx-v3/rs10wp9/
Do you mean where is a SIM card? If you have a Motorola V3 razr you will remove the battery door, There you will find the battery and just beneath it off centered to the right, you will find the SIM card. The battery needs to be removed in order to safely remove or insert the SIM card.
yeh it seems that ur sim card is no more working. it happens sometimes instantly. u have to use a duplicate sim of the same #. if u want to keep this #.
Try rigorously cleaning the sim card and phone connections (also battery connections - after reading forums the batteries on V3's are often to blame for their problems) with a cotton bud then leave the phone off without the sim card in it and charge it overnight. Then put in the sim card and turn the phone on. This might help. My V3 often says Insert SIM and it is very annoying so i'm getting rid of it but those methods have worked for me.
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
battery will not stay charged in my motorola moto raxr [email protected]
