Question about Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag MDB9150 Can you please tell me how to remove the uppper spray arm. It is plugged with fish debris and I don't know how to remove it so I can clean out the holes.
  • Anonymous Jan 06, 2008
    how do you remove spray arm so you can take the clogged food out of the tray below?
  • Anonymous Mar 12, 2014
    how do you remove the tower from the spray arm on a maytag dishwasher
You just have to gently pull it doward.  It should unplug relatively easily.  To reinstall it, just plug it in it's shaft.
Roger
Posted on Oct 28, 2007
SOURCE:
The detergent door on the Jenair dishwasher opens but the detergent stays in the cup
Hello.
Two things come to mind:
1. Check the spray arms for pluggage, particularly at the tips. If the spray arms are plugged up, they can prevent the detergent from being dispensed. The easiest way that I know of to remove debris from the spray arms is to remove the arm and use a piece of wire (paper clip) to rake out the debris in the tips, and poke holes of the plugged nozzles, then wash the arms out over the sink.
2. Get the water in the sink as hot as possible just before starting the washer. The hotter water will help dispense the soap more readily, and help to clean the dishes better.
Best regards, --W/D--
Jun 21, 2011 | Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
Hello, Im trying to diagnose poor cleaning of glasses in the top rack of my Fridigaire FDB751SCB0. everything seems to work fine but while testing I noticed the upper arm isn't spinning. the lower arm...
Hello; first thing to check, which you don't mention, is which side of the glasses aren't coming clean; the outside, which would be caused by the TOP spray not working properly, or the INSIDE, which would be caused by the spray BELOW the top rack not working. The most common problem causing a spray arm not to turn, and/or poor cleaning, is debris blocking some or all of the spray holes in the arm. Best and easiest way to check them is to remove them; they usually are easily removed with a large wing nut or screw in the center. (Don't drop the screw, if you do it will ALWAYS find it's way to the hardest spot to retrieve it from in the whole dishwasher!)
Once you have the spray arm(s) out (this might be a good time to clean them all) you may notice pieces of debris partially protruding from the spray holes. DON'T pull them out; use something to push them back inside the spray arm. Pulling them out can enlarge and mis-shape the spray holes.
Dislodge any pieces inside the arm by firmly rapping it against a firm but padded object, and shake the debris out over the sink, catching it in a paper towel so it won't go down the drain. Be careful, as broken glass is often inside the spray arms, picked off the bottom of the tub and fed through the pump to the sprays.
Once you don't get any rattling inside after several "raps" on the padded object, the arm should be clean.
Cleaning these spray arms periodically is a good idea even before you have trouble.
Hope this helps, and good luck!
Alec
Jun 04, 2011 | Dishwashers
Top water wand does not turn
Does the spray arm spin if you push it with a finger? If not, the plastic bearing is in trouble--pull down on the plastic pin under the lower center of the arm which should release the arm. Check the spray holes for plugging and any split seams between the two halves. Check the bearing area for any stray debris. If it doesn't spin because little water comes out of the bearing area, then the likely problem is either a plugged screen in the bottom area under the lower spray arm tower, or a plugged port on the bottom deck under the pump impeller parts. You will have to disassemble the entire lower tower assembly down to the deck to service this area--make notes as you remove parts so that it goes back together properly. Soak the large screen in hot water and white vinegar solution (50:50) to remove the white hard-water deposits. Check the lower spray arm for hole plugging and split seams as well. Our Maytag washer suffered the same problems and by changing detergent brands seem to have no further events. Hope this helps!
Oct 10, 2010 | Maytag Dishwashers
Dishwasher makes grinding noise when you turn it on
There is something in the shredder plate under the spray arm. To clear this you will need to remove lower spray arm and then using torx driver remove the screws holding the housing together and remove the housing to get to the debris underneath. Good luck and hope this helps.
Mar 03, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Want to know how to clean the arms
here is a breakdown of the inside of the machine. if the spray arm is not plugged, check the filter screen for debris. also check to make sure the wash impeller is not bro250ken. hope this helps a little.
Oct 24, 2009 | Maytag MDB7100AWB Dishwasher
Dishes not clean
Depending on the age of this Maytag Jetclean II, you either have a failing pump motor that would need to be replaced.
First step is to clear the filter that is beneath the lower spray arm. (Tools required) Remove all debris you find. Then place a bowl or large cup of vinegar inside the empty dishwasher with no dishwasher powder added and run the unit for a full or short cycle. Use either Cascade or Electrosol powder for the next 30 days, never use gel or tablets in any diswasher.
Please report back what you find and do.
Mar 15, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5651A Built-in Dishwasher Logo
294 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
